Old 04-19-2020, 04:25 AM
Echo studios Echo studios is offline
Default Switching to XMON using a Dangerous 2-bus LT summing box - help with connections
How would you hook an Avid HD 16x16 I/O to a Dangerous 2BUS LT and output the audio to a XMON.......its giving me terrible headaches...
Right now, I'm using the Lightpipe Digital out from my 16x16 connected to the light IN of a Presonus Central Station to monitor the main mix summed by the 2BUS in Protools.
what if I want to be able to use all the cue outputs and external inputs with the XMON and still be able to use the 2BUS...
Anyone can help?
Thanks,
PT HDX2 / Ultimate / D-Command ES 24
MP Dual 3.66mhz ( 6-Cores) / 128GB / SDD 8TB
OSX Sonoma 14.4
Dan Desilets
Mix/Mastering Engineer, Guitarist, Composer
New Website live @ www.yuccamusic.ca
Old 04-19-2020, 04:30 PM
Led Led is offline
Default Re: Switching to XMON using a Dangerous 2-bus LT summing box - help with connections
Connect the 16 outputs of the 16x16 converters to the 16 inputs of the 2 bus LT, then the main out of the 2bus LT to the main inputs 1(L) and 5(R) of the xmon.
Xmon then replaces the Presonus as your monitor controller. All the wiring diagrams for the xmon db25 connectors are towards the end of the D Command manual.
Old 04-19-2020, 04:34 PM
Thanks as simple as that!
OSX Sonoma 14.4
Dan Desilets
Old 04-19-2020, 04:53 PM
Led Led is offline
Sorry, slight typo - the Monitor out of the 2BUS goes to the xmon inputs, the main out of the 2bus goes back to 2 inputs on the 16x16 so you can record the summed mix back into Pro Tools.
Old 04-19-2020, 05:04 PM
I was just about to write about the summed mix...This is what I thought I normally used 15-16 as the print inputs on the 16x16.
OSX Sonoma 14.4
Dan Desilets
Old 04-19-2020, 05:11 PM
But the Main problem I see is with Cue mixes....since I'm throwing all 16 outs of the HD into the 2BUS leaving me nothing to send to...
OSX Sonoma 14.4
Dan Desilets
Old 04-19-2020, 07:13 PM
YYR123's Avatar
YYR123 YYR123 is offline
This is where people use the 96io’s...
Don’t laugh - I’m serious -
You don’t necessarily care about the quality of the HP cues....run a 96 in there to cue out to.....
Daniel
Old 04-19-2020, 07:29 PM
Led Led is offline
If you need to send a different mix to the headphones , then yes you'll need either an extra converter as Daniel said, or only have 14 inputs to the 2bus and use the other two for cue mix. If you don't need and individual cue mix you can just send the control room mix to the headphones up the monitor section of the D Command by setting the 'Phones' source in the studio section to 'Mn' using the 'set source' button under the level pot, which will cycle though the Main monitor feed and Cue 1 and 2.
Old 04-20-2020, 04:59 AM
I think I may go and drive 96 route. Is this still supported in PT ultimate 2019?
OSX Sonoma 14.4
Dan Desilets
XMON or Dangerous NickFLZ ICON & C|24 10 02-16-2013 02:13 PM
Question to Dangerous summing box owners? Eduardo Apolonia General Discussion 8 04-19-2012 03:25 PM
Anyone using a dangerous d-box with 003rack?/Benefits of analog summing? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 06-03-2009 11:17 AM
Analog summing, Dangerous vs. Mackie? FredrikThomander Pro Tools TDM Systems (Mac) 43 08-20-2004 03:58 PM
Dangerous 2bus analog summing Bryan Cook Pro Tools TDM Systems (Mac) 15 06-22-2003 12:29 AM
