Old 11-14-2018, 07:44 PM
nightwaterproject nightwaterproject is offline
Default Lost the red playback/record cursor for recording
Please help. For some reason when I opened my Protools 11 yesterday my red cursor for recording vanished and I don't know how to get it back. If anyone knows how I would greatly appreciate it! Thank you so much!
2nd issue:
Right now I just have the regular blue cursor so when I hit play or record, it starts there. Then when I hit Stop and hit play again it keeps going and doesn't restart at the original cursor location.
Old 11-14-2018, 08:35 PM
Default Re: Lost the red playback/record cursor for recording
it is unclear what you are describing, can you post a screenshot. Make sure the track is record armed when you do that.
Old 11-15-2018, 04:48 AM
2nd issue:
2nd issue first as that's the easiest - check whether you have 'link edit & timeline selection' enabled or not.
The first issue needs more explanation. And Darryl has that covered.
What would help is some system info like what exact PT11 version do you have and what's your operating system?
Jack
QAPLA!
Old 11-15-2018, 10:05 AM
I unfortunately cannot get a screenshot from my computer as I'm at work; however I found a screenshot from online.
Attached is a screenshot of what it looks like. There is a blue line between measures 13 and 17. This is where the playback starts however I used to have another line that was Red where recording would start, not playback.
I can get you my PC and Protools specs this evening.
Old 11-15-2018, 07:32 PM
I'm not sure what happened to my previous I posted this morning so I'll try to explain it a little better below...
The red icon/cursor I referred to is the part where the track starts recording. The blue icon/cursor is where the playback starts. If you see my attached screenshot between measures 13 and 17 is the blue line. There should be a red line after that or somewhere there but it's no longer there.
I'll try to update this thread tomorrow with my computer info and exact Protools version etc.
Old 11-16-2018, 05:37 AM
For one thing the measure position indicator is showing somewheres in measure 33 - try zooming out and see if it's there. Also you won't see a red cursor unless the track you're recording is is record enabled. We really need that system info and exact PT version.
Jack
QAPLA!
Old 11-16-2018, 10:58 AM
You were right as it was off to the side and I was able to get the red indicator back but now i don't have a preroll before it records.
My version is Protools 11.2.1 running on a Alienware Windows 7 home premium 64 bit laptop. Intel core i7 CPU @ 2.70 GHz.
Old 11-16-2018, 12:15 PM
I suggest taking a read through the PT user's guide aka The Manual; take your time going through it as well as understanding the basics.
Jack
QAPLA!
Old 11-16-2018, 12:33 PM
I will do that. Thank you for your time.
Old 11-17-2018, 02:47 AM
Drew Mazurek's Avatar
it was moderated because you're a new member posting pics.
www.drewmazurek.com
Playback gets lost or distorted while recording - Pro Tools 8/M-Audio Profire 2626 xiauoko Pro Tools M-Powered (Win) 13 09-27-2011 03:39 AM
Cursor & playback jwd65 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 07-05-2010 07:50 PM
What is the setting to record from cursor? jccrtv Pro Tools TDM Systems (Mac) 3 01-15-2008 12:47 PM
7.4 Cursor Playback & Record Weirdness - New Feature... The Weed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-13-2007 11:36 AM
scrolling cursor during playback/record david holmes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-24-2004 06:00 PM
