Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 10-02-2019, 08:14 AM
stephen.r.banville stephen.r.banville is offline
Default AAE -30001 error w/ Sonarworks reference 4
Hi All,
After wrestling with AAX 64 bit unrecognized errors with macOS 10.11.6 and PT 12.8.3, I decided (per-recommendation from Avid and some folks here on DUC) to upgrade to 10.13.16 (High Sierra) and PT 2019.6. I'm running on a mid-2012 Mac Pro (Cheese grater). I no longer see the invalid 64 bit AAX error anymore due to the IOS 13 update, but now I'm seeing AAE error -30001 whenever I try to launch Sonarworks reference 4 within PT. I have a feeling this is more to do with 3rd-party non-iLocked plug-ins but who knows. I can upgrade to Mojave 10.14.x once I get a Metal supported GPU PCI card for my Mac, but for the time being I would like to know if anyone else has seen this issue.
Thanks,
Steve
Old 10-02-2019, 03:45 PM
jeam25's Avatar
jeam25 jeam25 is offline
Default Re: AAE -30001 error w/ Sonarworks reference 4
Excellent thanks for the info !
- Jesus Alvarado -
Keep the volume UP !
Old 10-02-2019, 04:00 PM
arche3's Avatar
arche3 arche3 is offline
I am still on the last high Sierra build. And the current PT ultimate. 12 core cheese grater. Hdx. Sonar works ref 4 works fine for me. No crashes at all.
Sent from my SM-G975U using Tapatalk
Old 10-03-2019, 09:29 AM
Are you running 10.13.6 ?
Old 10-03-2019, 09:33 AM
arche3's Avatar
Yes. 10.13.6
Old 10-03-2019, 09:48 AM
Yes. 10.13.6
Makes me wonder if the security patch that I installed for 10.11.6 has affected some files in macOS causing this new issue that only a fresh install can fix ? I really with Avid would get to root cause on this issue
Old 10-03-2019, 09:58 AM
JFreak's Avatar
JFreak JFreak is offline
I'm sorry to say but most likely Avid has zero interest in poking around ElCrap any longer, because the current PT version does not support it
Janne
Old 10-03-2019, 09:59 AM
JFreak's Avatar
Well then, maybe re-install and re-auth those plugs?
Janne
Old 10-03-2019, 10:14 AM
I've current upgraded from PT 12.8.3 to PT 1029.6 and updated my OS from El Capitan to High Sierra latest and still see the AAE error -30001. The plug-in lods fine now and I can see it in my available plugs in PT, but when I try to insert it, I get the AAE error. So this is really a completely new and different issue that doesn't appear to be affecting to many people.
Old 10-03-2019, 12:01 PM
I don't know if I can get this answered but I would like to understand is what does AAE error -30001 really mean regarding "insufficient resources" ? Is this a plug-in permissions issue, incompatibility issue (which I doubt b/c other folks are using this plug with 10.13.16), registration records with PT that the plug-in is not assoc. too ? Iv'e found other reports of this error with no solution provided. Really hoping this doesn't mean a fresh re-install.
Sonarworks Reference 4 ASIO Wawili_Sound Pro Tools 2018 2 01-23-2019 12:58 AM
Sonarworks Reference with HD OMNI and HD Native card abt AAX Plug-ins 4 11-17-2018 04:25 PM
Error -30001? Benny_Cha_Cha Pro Tools 12 2 04-04-2017 08:09 PM
revoice pro 3 gives audiosuite error -30001 joeinsb Pro Tools 12 4 02-15-2017 11:25 AM
AAE -30001 Error with VTM Dot Pro Tools 11 5 03-18-2015 02:37 PM
