#31
Re: PT8 constant -6101 cpu issue, Let's do something
Ok so I made some tests, I changed my daisy chaining setup.
I mac FW800> HD > HD FW800 alternative out > Lacie Flat Cable > Pro Fire 2626 FW400 in Test 1 I used a template sessions created by digi. 32 tracks all insert with EQ II and Compressor with 1 reverb, 1 delay, 1 chorus. 1 Master Track and on click track Be able to record until the maximum size I allocated to pro tools (10 mins) Playback Engine buffer size is set to 512 samples 1 Processor CPU USage Limit 90% The error didn't came out but the click sometimes drop or get slower Very musical.... anyway I tried different setting and started from 128 samples with 2 processor but it crashed after 4 minutes recording. Should be great with a band but not in an another situation. Getting little bit more stable with 512 I made the same test with all the EQ III and compressor plug ins off but the click still drop. Anyway it's not perfect but I could record 10 minutes of audio without 6101. Test 2 It's a rough Mix with 11 tracks with some plugs-ins, master tracks 3 reverbs, 1 aux track. System quite responsive if I don't have background task. I had to reduce the CPU usage limit to 85% to get more response. Playback Engine buffer size is set to 512 samples 2 Processor CPU USage Limit 90% CPU Bar is jumping at 30% seems stable With one processor it's jumping to 50% get lot of errors, getting hard to handle. So digi said it was better to run with one processor that's false ! The third test will include Rewire and software instruments but i'm not very enthusiastic. I still have some errors and I actually do very basic things. System looks like little bit more stable but it's far away to be perfect. |
#32
That's the exact FW Hub that I have.
Once again, there will be naysayers. But it works for me, so what do I care.
2.66 gHz iMac running 10.5.7 w/ Profire 2626 & Pro Tools 8.0cs3 |
#33
In looking at your drive again, it appears that it's configured as a RAID 0 or RAID 1. Is that the case here? If so, that's the problem - Pro Tools does not work with RAID systems. |
#34
Yes there is a RAID option, don't know if you can read japanese but this HD enclosure is set to support 2 drives that's why there is a RAID switch, you can setup as mirroring / spanning or striving (directly translate from japanese don't know if it's the exact English word or not)
I just have one drive in my enclosure so basicly RAID shouldn't be active, but I don't know maybe it's natively active. My enclosure jumpers are set on the RAID 1 mode (mirroring). I will try with a non RAID FW Hard Disk and let you know. if I have to change my HD which on do you recommend ? I heard about glyph |
#35
Ah! Ok, I think we're onto something then. That drive, even if you're only using 1 drive in the case, still will be seen as a RAID volume. It's built into the hardware and that almost certainly is the cause of your errors. There are many good drives out there - Glyph, OWC, EZ-Quest, etc. My personal favorites are the OWC - either as the complete drive or the DIY case + drive that you install yourself. I like the dual drive models that don't have RAID - I set them up to backup automatically on a set schedule. |
#36
Ok I hope it's working well because glyph HD (seems to be the most easy to find here in Japan) are quite costly. And I saw posts about people using glyph HD and still have troubles.
So lucent chipset is trouble free right ? |
#37
Lucent/Agere chipsets are fine - we solved that problem back in 7.x...
#38
My IcyDock MB559UEA enclosure has the Oxford 924 chipset, but I still have frequent -6101 problems using the Firewire 400 connection (with PT 8 M-powered, that is. No problems whatsoever with any other audio software, btw.). I've gone through troubleshooting steps digi recommends, and still have problems.
Avi |
#39
Can you visit the Help Us Help You thread and post all the information necessary? When you say you've done all the troubleshooting steps - what have you done, exactly? Do you have previous posts that we did troubleshooting with you? |
#40
Can you confirm the fact that is better to put the drive before the audio interface ?
ERROR -6101 constant | bakerja | Pro Tools 11 | 11 | 11-08-2013 07:27 AM |
Constant -6101 errors while recording | bleen | macOS | 21 | 05-29-2013 05:17 PM |
PT8 constant -6101 cpu issue - HELP! | Dozerbabar | Pro Tools M-Powered (Mac) | 89 | 06-15-2010 11:48 AM |
Constant error messages (-6101), (-9128) | MdotCash | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 42 | 07-14-2009 03:15 PM |
Constant -6101 errors | mpeddle | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 03-10-2009 09:03 AM |
