PLUGGO 3.1 OSX IS A-GOGO!!
IT'S OUT,,!!!
My world is complete,,, PLUGGO 3.1 |
Re: PLUGGO 3.1 OSX IS A-GOGO!!
good news.
how long until the runtime environment??? i want gleetchplug for OSX a lot... |
This is an updated post re how to get free pluggos into Protools
OK, i'll do a summary of the Pluggo "free" path for OSX, sort of a thread summary. First of all, install Pluggo Runtime from http://www.cycling74.com/products/dlpluggo.html (NOT the full demo/app) of Pluggo This will install various files on your computer, including a "Pluggo-RTAS" file in : Library - Application Support - Digidesign - Plug-ins (where your standard Protools plug-ins live) it will also create a folder called "Pluggo" in Library - audio - plug-ins - VST. Download the free pluggos from the links below, and put them into that Pluggo folder. You will then be able to insert these instruments/FX into audio, auxiliary and instrument tracks in Protools. * Some of these are still OS9 pluggos, but still work in OSX. You can read through this thread again to see which of these OS9 ones will still work under OSX * Universal Binary pluggos will NOT work on non-Intel compters Also, you can get more free pluggos by installing Pluggo Jr from http://www.cycling74.com/products/dlpluggo.html ************************************************** ********* FREE UNIVERSAL BINARY PLUGGOS : Colourtone Free / Phasetone http://www.tritonedigital.com/ Squid-Delay - goes up to 1000 ms (1 sec) of delay Squid-Delay Mini - goes to 100 ms http://arvidtp.net/downloads.html Fineline synthesiser http://cascom.se/kl/programs/fineline.html (also "Drumachine R8" - drum synth - for 2 euros] Eight Octave Filter Bank - emulation of 8 octave filter bank released in 1971 by EMS http://web.mac.com/pierre.couprie/iW...er%20Bank.html Percolate pluggos: harm-Z; Metaflute; Quadracomb; Snow; Weaver http://studios.brown.edu/~arvid/sw/PeRColate_builds.zip sbl - a collection of pluggos (v 0.2) calcutility - Some math conversions Channelstrip - A dirty Channelstrip Crumbling - A picky noise gate dehnuebung - that omnipresent granular sampler ezeq - Easy EQ InFragrantri - Stutter + Pitch Shift Multibanddistortion - ... Island - That s-s-s-s-s-s-s-s-s-sound (actually quite boring) retardando - Roll through your audio sblmunger - that omnipresent wrap for the great munger~ external sbllooper. Shifty - Ringmod or FM your signal Ueberstaettigung - Tape Saturation http://stephenlumenta.com/?page_id=30 Scrambler - 'It slices, it dices. It swirls audio around a couple of centers.' http://www.xfade.com/max/scrambler/ Paein - universal panner http://asylumstudioproductions.com/plugins.cgi Poly iV - an emulation of the Korg Poly 800 synthesiser http://www.wildfrontear.co.uk/ Ninja Plugs - suite of six plugs inspired by GRM Tools. http://soundninjastudios.net/sns/NinjaPlugs.html Binaural Beat generator - Generates binaural beats with stereo synch and main parameter's portamento http://www.franzrosati.com/bbg.html le Synthe - emulation of classic EMS synth http://web.mac.com/pierre.couprie/iW...905839F7C.html ck.altostratus : a strange midi instrument based on PeRColate´s blotar~ ck.clock : well, a clock! How useful can you get? ck.comp : a compressor ck.cycring : a ringmodulator ck.dram_d : 6 voice drum synth with reverb and MIDI control ck.envfilter : to adjust filtercurve, click “X” button and drag curve with mouse ck.fader :fade in and out within a pre-defined time ck.impulsemachine : sequences the Abelton drumsampler 'Impulse' ck.phasemod :a nice phase modulation plug-in. ck.stepbystep:created for a drummer. play a MIDI note sequence with one hit. You could e.g. play simple melodies with a MIDI drum pad or trigger various other samples on other tracks etc...... ck.spectraldelay ck.stepfreeze : step and freeze! with variable “freeze” time ck.stranger:mysterious delay lines. ck.talkingnumbers : experimental noises galore ck.timer : a simple time counter , For Live´s Session view. http://christiankleine.com/Site/4_pluggo.html FX : maR grainfield / maR compressor / maR limiter / INSTRUMENTS : Riss Duo / Sep / August Synthesizer http://www.audiooo.com/jp/freestuff/pluggo.html Mirror - reverse play Constantin - simple buffer delay Black - black noise filter masking Bins - frequency shift Cross B - A signal is convolution with B 512EQ 512 band FFT EQ Complex - A signal is convolution with B Bus Sends signal to other VST (with Complex and CrossB) Amp1 - simple amp simulator NN - sample rate reduction Tapecho - tape echo simulation http://www.geometricdeck.org/ (then click "Tools", then click "1" or "2" to see plugs ) Delay Finder - "a 2-part plug-in that can compute the delay, or latency, between any two audio signals in a DAW" http://www.studio6digital.com/downloads.html PolyRythmic Sequencer - a Vsti rhythmbox Bazz-ID - bass synth based on FM synthesis with 3 Bass levels http://www.soultracker.net/typo/index.php?id=158 gatr - beat-syncronised gate / multimode filter / delay/reverb werd - 2 independent delay lines, a multimode filter, and a re-pitcher gleck - granular delay/repeater with pre and post effect waveform displays reanimator - granular pitch shifter, a stutter/repeater and a sonograph dirtsky - grain-based mangler with 3 way harmoniser Glub - step sequenced filter like gatr, contains a 3-way pitch harmonizer http://homepage.mac.com/andrew_burgess/plugin.html Collideascope : 'Music is Movement ' collection (27 pluggos) http://www.artassault.org/software/collideascope.html will list them later Glitchbaker, Glitchbaker 2 http://www.jabucnjak.hr/components/c...tchbakerUB.zip http://www.jabucnjak.hr/components/c...chbaker2UB.zip Dax http://zombideo.net/plugins.html aLib VST "Collection of vst pluggins for control information generation, audio synthesis, audio analysis/resynthesis and other peculiarities." ali.iana-mod.vst ali.pitch-filt.vst ali.rhyth-phr-multi3.vst ali.resonators2~.vst ali.anal-resynsth+.vst ali.paf-tester07.vst ali.phasor-interp-stepseq.vst ali.lemur.vst ali.midi-continuator2.vst ali.jm.beatspace2.vst http://alimomeni.net/aLib-vst Scratcher "Scratcher was an idea I tossed around for about a year before I started development. I wanted to make turntable scratches that were inhumanly complex in their fader work and record movement. I also wanted a number of other features like the ability to scratch musical phrases from single note samples, and the ability to easily insert one scratch into another." http://web.ics.purdue.edu/~afaulsti/...scratcher.html ************************************************** ********* Post in this thread when any of the pluggos below go to Universal Binary ************************************************** ********* OTHER LINKS FOR FREE PLUGGOS : http://www.sonoria.pl/jk/pluggox.html JK (give him a donation folks!) http://www.wildfrontear.co.uk/plugs.html The Lone Roger http://www.music.columbia.edu/PeRColate/ The Percolate Collection http://www.angelfire.com/sd2/wheat/ Wheat’s collection http://www.tritonedigital.com/products.htm#phasetone Phasetone http://www.tritonedigital.com/products.htm#colortone ColorTone Free http://refusesoftware.com/freeware.html Refuse Software (just "RTA") http://www.laut8leise.de/asa.html Laut&Leise http://launch.groups.yahoo.com/group/16tone/ You need to join the yahoo group to get this one , Victor Cerullo's VET-1 synth in the Files section : 'VET1_Pluggo_Synth_21.sit' http://www.hecanjog.com/software.php Icy 1.0 "this os x vst/au plugin is modeled after grmtools freeze" NEW TO LIST AUGUST 2006 : ************************************************** ********* Scrambler - “It slices, it dices. It swirls audio around a couple of centers” http://www.xfade.com/max/scrambler/ ************************************************** ********* Eight Octave Filter Bank - emulation of 8 octave filter bank released in 1971 by EMS http://web.mac.com/pierre.couprie/iW...er%20Bank.html ************************************************** ********* AdditiveSynth / FM-Synth / DeepSpace (automated sine waves) / ModWheelMayhem / ModWheelScales / NoiseySynth2 / PannerDeluxe / Pierre'sPlayhouse. http://oak.cats.ohiou.edu/~phillipm/ (scroll down to "PluggoVST.zip") ************************************************** ********* FX : maR grainfield / maR compressor / maR limiter / INSTRUMENTS : Riss Duo / Sep / August Synthesizer http://www.audiooo.com/jp/freestuff/pluggo.html ************************************************** ********* Verzerrounder - rounds down the digital value of your audio. The effect creates a unique type of distortion. http://verzerren.com/001/index.php?blog=1&cat=30 ************************************************** ********* Matrix Synth http://homepage.mac.com/plesecq/Menu6.html ************************************************** ********* NES Square Channel - Nintendo Entertainment System square channel emulator http://www.mmonoplayer.com/projects.html ************************************************** ********* Burnt Toast - automated looping plug-in http://www.audibleoddities.com/twerk/index.php?p=sof ************************************************** ********* Supertrance : A quite simple subtractive synthesizer using Csound. It runs as a plug-in, but only one instance at a time Sd1 delay : is a delay plug-in with svf filter and overdrive on feedback signal. trancegate : a 16 step stereo/mono gate effect http://www.audiomasher.com/programs.html ************************************************** ********* repper : is a sequencer driven repeating effect. rndelay : is a 8-step random delay. satter : is a sequencer driven saturation/gater effect. the sequencer controlls the saturation amount. zipper : is a envelope driven repeating effect. you can switch between 3 envelopes with a step sequencer. http://www.ekodsp.net.ms/ ************************************************** ********* koochoh : An Air-Conditioner Noise Emulator. nezumi : 1/f Auto Tremolo uguisu : Waveshape Effector with many parameters http://p0k.net/ ************************************************** ********* Collideascope Plugin Collection for Pluggo - " An ever growing collection of plugins designed to be used together with alternative controllers such as midi drum pads, joysticks, microphones and virtual reality gloves to shape the the plugin's audio output." beat detector / bonkalorithm / midi2trigger / tempo to ctrl pulse / tempo to ctrl wave / ABS max / ABS min / audio segmenter / basic roll / choral harmonizer / cutomatic / LFO volume control / munger / noisegate / oraison / pitch bender / resonator / rythm guided EFX / simple pitch shifter / spectral average / time warper / volume control / granular sampler / random sample player / tape head sampler / blow botl / chebyshev / format synthesizer / messy flute / moto rev / scan synth http://www.artassault.org/software/software.html ************************************************** ********* additive synth / pothole / draw me / vortical http://home.lagrange.edu/mturner/Mit...e/plugins.html ************************************************** ********* ck.altostratus : a strange midi instrument based on PeRColate´s blotar~ ck.ambienter : ambient sound generation ck.clock : well, a clock! How useful can you get? ck.comp : a compressor ck.cycring : a ringmodulator ck.envfilter : to adjust the filtercurve, click the “X” button and drag the curve with your mouse ck.flipseq : can read a file or record n realtime and re-order it ck.granutha : a granular audio effect ck.phasemod :a nice phase modulation plug-in. ck.stepfreeze : figure it out! ck.bitxoe : generates high crisp audio effect ck.talkingnumbers : experimental noises galore ck.timer : a simple time counter http://www.christiankleine.com/Site/...downloads.html ************************************************** ********* VSTi SimplAE : " vstSimplAE is a four drumsynth base on FM synthesis. You can create each drum sound, change their duration, harmony, frequence and get some very strange sound." http://www.soultracker.net/botch/vstSimplAE.htm ************************************************** ********* glitcher http://www.sendspace.com/file/p6ezt2 ************************************************** ********* sreverbs : reverb dring : ring modulator quadflange : chorus / flange harmote : pitch transposer shsyn : synthesiser http://www.nn.iij4u.or.jp/~shirano/spy/spydoc.html ************************************************** ********* TrapDrumKit (AnalogDrumKit vst instrument) SynthFm3 (FmSynth vst instrument) SynthSine (FmSynth vst instrument) MiniBassline (Bassline vst instrument) TrapFilter (fft filter vst) Trap16Delay_01 (16 delay vst) Trap4bandsDelay (4 delay vst with fft filtering) MiniTrapLooper (a simple loop player) All from : http://eolifize.free.fr/DownloadMaxMsp.htm ************************************************** ********* hrtf / tapecho / 512 eq / cross b / bus / nn / complex No further info on these! http://www.geometricdeck.org/code/ ************************************************** ********* Pajaman's Pluggo Collection http://perso.orange.fr/pjmn.pjmn/ ************************************************** ********* FutureBooster is a granular synthesizer for ambient applications. http://web.media.mit.edu/~meyers/futurebooster.html ************************************************** ********* Bassquaker - simple sine wave distortion tool http://www.dropthelime.com/downloads.htm ************************************************** ********* Stereo Panner / More Stereo / Multi Filter / Super Tremelo http://eamusic.dartmouth.edu/~mfrengel/freeware.html ************************************************** ********* Jnote.org plugs Tapcity, Mungekin, Reeverb, MouseMusic, MouseMusic2, VolumeMod, MetroNome http://jnote.org/download.php CURRENTLY DOWN - MAYBE BACK ONE DAY ?? http://postsomnia.com/ Matthew Lyon http://gdavis.dyndns.org/plugins.html Greg Davis http://www.ienproject.com/gleetchplug/ Tobor Experiment - GLEETCHPLUG http://www.davidstanford.com/david/bacon.html David Stanford ("Bacon") (following one seems to have completely disappeared) http://www.synthesisters.com/hyperma...t03/11350.html (see the page bottom " application/x-stuffit attachment: strand_Gil_Tertre_pluggo.sit " , these are also described at http://www.plataforma-ltw.com/03/ltw...ribuciones.php in the post "Strand/Gil Tertre Pluggo", but the file itself doesn't properly from that link) |
This will triple the amount of free rtas plugs available for OSX. We'll need a new list soon. The VST wrapper will of course open flood gates but the great thing about pluggo runtime is that it is totally free from start to finish & most of the plug-ins are of really good quality.
Just been on the Gleetchplug site & Tobor is saying sometime in February for Gleetchplug. |
just in case ,
here´s the link to the OSX runtime installer http://www.cycling74.com/products/dlpluggo.html#system best PS:any hints how to install this under OSX?
last: PT11.3.1 |
(problem fixed , edited post)
Guys, just make sure you download from the link that says "Download the Pluggo 3.1.1 runtime installer for Mac OS X (updated 11 January 2004). " |
The PeRColate Pluggo's are also available now for OS X; they're at http://music.columbia.edu/PeRColate
I wil be updating all my Pluggo's at www.wildfrontear.co.uk as soon as I can get round to it. I'll post here when I've uploaded them. |
Thanks for the info guys!
I figured the issue with with the VST folder out by installing the Pluggo demo, bu your info helped me to UNDERSTAND what´s going on. best
last: PT11.3.1 |
Just a note that jK at http://www.sonoria.pl/jk/pluggox.html has ported a few more of his Pluggos, here's the full current list of his ones :
Piczer is a crazy pitch change-distortion plug ------------------------------------------------------------------------ Ddram1 is a drum sample player. 12 pads, velocity, pan, reverse, pitch, sample region selection. *screenshot * NEW: pitchbend and LP filter added. ------------------------------------------------------------------------ Luppo1 is a RTAS looper, slicer, pitch change, tempo delay plugin. Load a loop, change tempo+pitch and trig it with MIDI notes. ------------------------------------------------------------------------ Peakme is a large RTAS peak meter with phase probe and scope. . NEW: MS decoding, mono monitoring, phase invert and more... ------------------------------------------------------------------------ Limo is a limiter plug with auto makeup gain. NEW! saving parameters. |
Pluggo jr | clausiii | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-21-2006 07:57 AM |
Pluggo on 6.7? | keny | Pro Tools TDM Systems (Mac) | 4 | 01-11-2005 04:35 AM |
Pluggo and FCP HD | Darin Donovan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-11-2004 07:29 PM |
who uses pluggo? | freakuincy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-05-2003 08:52 AM |
* PLUGGO 3 | peter parker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-05-2002 03:35 AM |
