Old 07-09-2006, 01:28 AM
tomcat tomcat is offline
Default question about focus channel fader
when I select a channel to be controlled by the focus fader, the focus fader doesn't jump to the value if the selected fader. It follows relative motion, though it looks to be a linear relationship, rather than log. as it is in a group. The bigger issue, though, is that when the controlling focus fader gets to the top or bottom of it's travel, the controlled fader jumps from whererver it is to the extreme end. I hope there is something I am not understanding, because this behaivior seems to render the focus fader idea kind of dangerous, if not useless.
tom
www.tompaul.com
Old 07-09-2006, 05:18 AM
digimidi's Avatar
digimidi digimidi is offline
Default Re: question about focus channel fader
They should be exactly the same. I would recal the faders.
Utility/test/faders/recal.
Gil
Gil Gowing
Principal
Digimidi Technical Services
Old 07-09-2006, 10:19 PM
right you are. recal fixed it.
thanks
tom
www.tompaul.com
Focus Fader when in VCA mode? audioluche ICON & C|24 5 02-06-2012 09:56 AM
D-Command: possible to FOCUS a channel from PT software ? bennym ICON & C|24 3 01-23-2011 05:52 PM
Can I lock a fader similar to ICON Focus Channel? macaholic Artist Series 1 12-15-2010 12:13 AM
fader focus question tomcat ICON & C|24 1 12-06-2007 10:54 AM
DControl Question window follow focus channel? GMitchell ICON & C|24 1 05-19-2005 10:54 PM
