Old 10-02-2018, 04:47 PM
cmbourget's Avatar
cmbourget cmbourget is offline
Default How to rename duplicate clips individually
Quick question for all. How to rename duplicate clips individually? If I rename a duplicate clip, the original is also renamed (and the opposite is true). I want to be able to rename each, even with 100 duplications. Thank you.
  • Pro Tools 2023.12 Studio, Nuendo 12, Samplitude Suite Pro X7, Wavelab 11, Dorico Pro 5, Melodyne studio 5.
  • Apollo X 16 and 7.1.4 studio (Focal Solo6 be, Sub, and Focal EVO)
  • Softube Console 1. UAD systems (USB3).
  • Mac Studio M2 Ultra 2023. 2T. 128 Go. + 2X 4 T NVMe ext.
  • AMD Ryzen 9 5950X 16-Core Processor 3.40 GHz 64 Go, full SSD
  • Roland V-Piano, Novation 88
  • Etc.
  • www.claudemarcbourget.com
Old 10-03-2018, 12:22 AM
inf0l inf0l is offline
Default Re: How to rename duplicate clips individually
Fastest way would probably be to do it outside Pro Tools using a batch renaming tool.
If you want to do it in Pro Tools, one way would be to line up all the duplicates on one track, open up an AudioSuite plugin like Gain and without changing the parameters, select 'Create Individual Files' in the drop down menu and then click 'Process'. You should now have individual clips instead of duplicates referencing a master clip...
Old 10-03-2018, 04:20 AM
cmbourget's Avatar
I take the Pro Tools solution. I also see that consolidating the clip works in this way. Thank you very much.
  • Etc.
Old 10-06-2018, 02:08 PM
JFreak's Avatar
JFreak JFreak is offline
Doesn't consolidate work for you?
Janne
Old 10-06-2018, 03:10 PM
cmbourget's Avatar
Yes, it works.
  • Etc.
Is it possible to auto rename clips in order of volume - velocity ? Spyderrp7 Windows 0 02-03-2018 12:58 AM
Neo Assertion Line 352 Error (rename clips) Dantranquilo Pro Tools 10 0 03-01-2017 08:47 AM
How to duplicate clips... that actually duplicate physical files? mooquu Pro Tools 10 4 06-04-2014 03:28 AM
Disassociating Duplicate Clips TheEdster75 Windows 3 03-17-2014 12:27 PM
can't duplicate/rename file bluemt Pro Tools TDM Systems (Mac) 3 03-13-2001 01:30 PM
