Old 07-31-2018, 01:26 PM
hoosierdraft hoosierdraft is offline
Default Routing an Aux to an Input fader
New to the Digi world and new to a D-Show Profile. All 8 groups are in use, so I'm left looking at Auxes. Can I route an Aux to an Input Fader? I want to take 6 drum inputs, route them to an Aux, insert to a Compressor and then back to an Input channel. Looked through the manual and did a search across the forum to no avail. Thanks.
Old 07-31-2018, 02:06 PM
Valentyn Valentyn is offline
Default Re: Routing an Aux to an Input fader
Use some low-delay plug-in which would have Aux as an input and Input as an output. Then bypass that plug-in to make it no-op (note that delay will still be added).
Old 07-31-2018, 05:03 PM
Excellent Valentyn. Exactly what I was looking for! Will try it out tomorrow.
Old 08-01-2018, 02:49 AM
Sorry, for not being clear: when writing "low-delay" I meant low latency.
Old 08-01-2018, 06:54 AM
Karel Noon Karel Noon is offline
Wich Plugin is the one with the lowest latency?
I always use „Trim“ for routing tasks like this one, but there might be a better option, without having to test them all by myself
Old 08-01-2018, 08:29 AM
emluper emluper is offline
You could always use the Old School method of using the direct out on the Aux to an AES output, then use a patch cable to loop it into an AES input assigned to a channel input. This way you don't lose a plug-in slot. I do this all the time when running monitors. Use it for Drum, Horns, and BGV subs.
Old 08-01-2018, 04:10 PM
RyanJ's Avatar
RyanJ RyanJ is offline
The latency of the plugin doesn’t matter really because you can disable the plugin, and the routing still works, that way you’re not adding hdx routing Latency or plugin latency, not using any DSP.
Ryan John
Principal Product Manager | Avid Live Sound
[email protected]
Old 08-02-2018, 04:20 AM
Oh yeah, I forgot about disabling.
Old 08-02-2018, 09:19 AM
Thanks all for help on the routing. Works like a champ.
Followup question. I am routing Kick, Snare, Rack Tom and Floor Tom to an input fader being fed by the plug-in that is fed by the Aux. I want to compress the signal at a 10:1-12:1 ratio. Should I use a compressor as a plug-in or use the input channel compressor? Pros and cons either way.
Old 08-03-2018, 10:01 AM
RyanJ's Avatar
You can do either, it's really about the sound at that point... there's nothing that the onboard comp is missing feature-wise, and the channel can be automated similar to automating a plugin. On-Board is lower latency, plug-in is slightly more... So really, just pick whatever you want in terms of sound.
Ryan John
[email protected]
Pre-Fader-Send and Pre-Plug-In routing briancares Tips & Tricks 2 12-22-2015 08:41 PM
Routing send fader to PC Dopamine ProControl, Control|24, Command|8 2 10-15-2009 03:44 PM
Routing around the Master Fader 2hip2b4real 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-05-2008 11:25 AM
Routing input 5 from 002 to input 1 Amplitube Live stoogee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 08-27-2004 12:56 AM
Routing output of master fader MPB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-14-2003 12:44 PM
