Old 07-10-2017, 03:09 AM
karumba's Avatar
karumba karumba is offline
Ohlhorst Digital
Default OD DeEdger by Tokyo Dawn Labs
DeEdger introduces a new way of reducing the hardness of audio signals without negatively altering the original signal qualities.
The plugin operates in a threshold free manner, thus can comfortably handle any input signal level, type, and dynamic range. Where other plugins might under or over process, DeEdger only applies processing if any hardness is detected. Once detected, the hardness will be smoothed with remarkable elegance. After its initial setup, DeEdger can be left in a “set and forget” configuration without further attention.
Intricate time and frequency dependent mechanisms allow DeEdger to provide a very transparent process throughout. The initial concept, developed by a professional mastering engineer, focused on the demands of modern audio mastering and has also turned out to be equally useful for mixing.
Key Features
  • Control the hardness of audio material while preserving dynamic impact and musicality
  • Suitable for complex stereo material, including individual tracks and subgroups
  • Low CPU load
  • Intuitive user interface
  • Set and forget
Ohlhorst Digital is a brand by Jan Ohlhorst. Initially developed exclusively for his work as a mastering engineer, these well refined products are now being made publicly accessible.
More details here:
DeEdger | Tokyo Dawn Records
Old 07-19-2017, 07:30 PM
Muddy-T's Avatar
Muddy-T Muddy-T is offline
Default Re: OD DeEdger by Tokyo Dawn Labs
A maintenance up date is now available;
1.1.0
# Added M-only and S-only channel mode option which can be setup by toggle-clicking the M/S button
# Added new "adaptive load" mechanism that dynamically unloads all filters & deactives all processing when there is no input signal
# Fixed bug where frequency change was not assigned under certain cases with "Focus Listen" activated
# Significantly reduced CPU load by further optimizing DSP framework
# Slightly adjusted Q dependent loudness compensation in "Focus Listen" mode
btw - If you think a hundred bucks is a lot of money for an intelligent, set-and-forget de-harsher/de-boxer/de-esser/dynamic EQ, like all TDR plug-ins the demo version is unrestricted in time and functionality. The only restriction is it won't re-call settings. (Remember track sheets..?)
Awesome!
T
"Don't look; listen!"
At work; 2013 27" iMac/i5/2.9GHz/8GB, OSX 10.8.5, PT 10.3.6
At home; Custom Made Mac (Hackintosh) i7 (3770 "Ivy Bridge")/3.4GHz/32GB@2400MHz, Samsung SSD 840 EVO 250GB System Drive, Samsung SSD 750 EVO 250GB Audio Drive, OSX 10.10.5, PT 12.8.1
HTML code is On
New TDR Limiter 6 GE by Tokyo Dawn Labs FabienTDR AAX Plug-ins 2 07-19-2017 07:08 PM
Dawn of the Planet of the Apes: Will Files on Pro Tools and Dolby Atmos Tom Graham Post - Surround - Video 4 01-01-2015 05:09 PM
How to go Mac at the dawn of Leopard? Yosemite 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-01-2007 09:07 AM
OT- Anyone here in Tokyo? valvebrother 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-14-2002 09:48 AM
PT LE and Tokyo 2.5 t0kdag0n MIDI 3 03-17-2001 12:05 AM
