Old 04-08-2006, 12:26 PM
wwicklund wwicklund is offline
Default Mix Window Freezes but Edit Window works fine.
I have learned a lot for you guys already by reading the boards, Thanks!
Now I am having a problem that I could not find the answer for.
I recently Recorded a Choir Concert for my school, I just set the mics up and let run, the concert lasted about 70 min. I had no problems getting a good recording. I Seperated all the regions by song and the exported regions as files. I then opened a new session for one song that I could work on individually. So I imported the file(s) to track, and added a Master fader.
The Edit window is working fine as far as I can tell, but when I switch to the Mix Window the faders are all frozen as soon as I try to move a fader, pan, or add an effect. They remain frozen, but the song continues to play.
The orignal session was recorded at 44.1 16bit
And when I created a new one I used the same settings.
When I did this same workflow with a piano recital it worked just fine.
Was something wrong with my workflow?
I could understand if my 70min session hung up, but I am now working in a 3 min session with only 5 tracks right now.
Here is my gear
PT 7.0
Rack002
Presonas96k
Sweetwater Creation Station Dual 3.2Ghz 1Gb RAM 250GBHD @ 7200RPM (basically made for PT by Sweetwater)
Old 04-08-2006, 10:49 PM
Default Re: Mix Window Freezes but Edit Window works fine.
Got it figured out.
It was a file naming issue, I think...
Anyways....working well again.
Old 07-10-2022, 10:30 AM
Crutchofmemory Crutchofmemory is offline
Hello- we are having the same issue and can't figure it out! Could you elaborate on how you fixed it? Thank you very much.
Old 07-10-2022, 10:57 AM
Ben Jenssen's Avatar
This is a 16 years old thread.
I wouldn't get my hopes up.
MC Control v2 Jogwheel use freezes edit window ronnievanoverveld Artist Series 3 09-09-2011 05:11 AM
edit window freezes while recording pisound Pro Tools TDM Systems (Win) 3 04-01-2010 08:30 AM
Trying to make keyboard shortcut for insert/sends F-J works for edit window only! crizdee Pro Tools TDM Systems (Mac) 4 01-30-2009 04:30 PM
Edit window freezes during playback 4times4mil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-11-2006 09:35 AM
edit window & timecode freezes intermittently zerovu Pro Tools TDM Systems (Mac) 1 06-15-2006 08:12 AM
