Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire and USB Audio Interfaces (Mac)
Old 01-14-2014, 08:36 PM
brroberts brroberts is offline
Default MBoxPro 2, PT 11.1.1, Mac 10.9.1
Had to do some updating and now MBoxPro 2 is not recognized by MBP 17" 2011. On PT 11.0.3 and OS 10.8.4 all was fine, but now I don't get the MBox to lock up with the Mac. USBPre2 is fine, PT seems fine, but not MBoxPro2. Trashed databases and prefs, reinstalled latest driver. Still no sync. Any ideas?
Randy Roberts
System Info:
MacbookPro 2.5 GHz Intel i7
OS 10.9.1 w/ 8 GB of ram PT 11.1.1
Rockstar 320 GB hard drive FW 800 - 800 about 3' long for recording
Internal 750 GB 7200 RPM Hitachi SATA drive not used for recording
MacPro 2009 16gb, 4 drives, 8 cores 10.6.8, PT 8
HD 3
MBox Pro 2, Presonsus SL 24.4.2, Sound Devices USB Pre 2, Magma T Bolt chassis with HDX
Old 01-16-2014, 07:32 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: MBoxPro 2, PT 11.1.1, Mac 10.9.1
Unfortunately 10.9.1 is not supported yet:http://avid.force.com/pkb/articles/e...nload/en379411
ALERT: Mac OS X 10.9 Mavericks
Updated Drivers have been posted for most of the current Avid audio hardware. Please select your hardware from the list above to see if a compatible driver is available.
Important Note: Mac OS X 10.9.1 Mavericks is NOT approved at this time.
Can you test the Mbox on another computer to see if it gets detected, to rule out a hardware issue?
Joel
Jame Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Intel S5000PSL / 2 x Xeon E5450 / 32GB RAM / Win 10 Pro
Pro Tools 12 HD / M-Audio Project Mix IO
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 01-20-2014, 11:47 AM
keenast keenast is offline
MBoxPro 2 works well on my system running osx 10.9.1 with 11.1.1. I do have issues with 11R though ! I have to run it through the MboxPro2 !
Old 01-20-2014, 04:02 PM
Thanks for the info. I found myself having to update, so I did. Since I have restarted the system a few times, it has started working. I don't use the MBoxPro 2 much, but do have some things coming up where I will use it. So, until supported, I hope it keeps working :)
Randy Roberts
System Info:
HD 3
PT 10.3.7 on IMac not recognize MBoxPro One Man Jury macOS 1 01-07-2014 05:19 PM
Multiple Hds with MBP and MboxPro JimmyM FireWire and USB Audio Interfaces (Mac) 0 11-08-2013 01:45 AM
Need Breakout Cable for MboxPro 3 nhmorgan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-09-2013 12:36 PM
MboxPro 3 App problem. kikoadbo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-10-2012 08:43 PM
when power on my MboxPro v3 keyframe Pro Tools 10 1 06-22-2012 12:10 AM
