Old 07-15-2009, 06:33 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default How to move several regions at once
In a project I'm working on, the entire piece begins with no intro...all instrumentation and the vocals come in at beat one. Artistically, I've decided I don't like that and I know want to insert a 4 measure intro to ease into the piece better. I have several tracks with several regions each through the entire song. I can't see how to grab all regions across all tracks and just slide the whole shooting match over 4 measures so I can insert an intro part at the front end. Can this be done?
Old 07-15-2009, 07:40 AM
Carl Kolchak Carl Kolchak is offline
Default Re: How to move several regions at once
Probably the easiest way to get the results you're after is to just "Insert Time".
Alternatively you could "select all" and drag the regions, or you could use the object grabber and marquee all the regions.
hope that helps.
Old 07-15-2009, 09:14 AM
DonaldM's Avatar
thanks, that was it. I couldn't remember what the function was called to look it up in the manual search.
Old 07-16-2009, 08:02 AM
You could also make a group of all audio tracks and then dragging any will move them all.
Old 07-17-2009, 04:24 AM
Vedat's Avatar
Vedat Vedat is offline
Quiet Art Ltd.
Insert time is best. Or you could group all the regions.
Easiest way to do this is tab on to the start of the earliest track and shift drag to highlight the rest. Or select all in the group enables window, tab to the front and hit shift+option+return to select the entire piece.
Make sure when you're moving regions this way that "automation follows edit" is enabled in the options menu.
Vedat
WaveRider + Defaulter (now with LKFS)
QuietArt.co.nz
Catchin' SYNC app
Old 07-17-2009, 11:07 AM
daeron80 daeron80 is offline
Or select all and Spot to bar 5.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 07-17-2009, 11:22 AM
audiogeekzine audiogeekzine is offline
Gotta love that there are multiple right answers to questions like this.
Don't forget region groups too!
@theaudiogeek
| www.EPICSounds.ca | www.AudioGeekZine.com | www.HomeRecordingShow.com |
Old 07-18-2009, 05:27 PM
DonaldM's Avatar
Thanks, guys. Appreciate it. Funny story using the Time Insert function. I used it on a recent project, but when I played it back, I noticed one of the tracks was completely out of sync now. I couldn't figure out why...and kept undoing and re-doing it. Then I realized the offending track...an instrument track...was still in Note view and not Region view. Has to be in Region view to move!
Old 07-18-2009, 05:30 PM
Sounds like a bug. PT8?
David J. Finnamore
Old 07-20-2009, 03:28 AM
Vedat's Avatar
Quiet Art Ltd.
Yeah, the view setting should not make a difference.
Vedat
QuietArt.co.nz
Catchin' SYNC app
Regions won't move, PT won't quit.... Arno Peeters 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 32 01-28-2011 12:09 AM
regions won't move! bontay Pro Tools TDM Systems (Mac) 5 01-25-2011 08:55 PM
Can I move regions and have the underlying playlists move also? smpkeys Pro Tools TDM Systems (Mac) 4 02-18-2010 07:30 AM
Can't move fade without its corresponding regions Richie Hamiltoe 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 02-22-2005 04:27 PM
How do I move markers with regions? ckerian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-24-2002 03:15 PM
