Changing track input/output assignments corrupts session files, causing PT to crash.
Working with M-Powered 8.0.3, Fast Track Ultra on Win XP sp2. I changed the output destination of the master bus for interface 1-2 to interface 3-4, and the program crashed. Reverting to the saved version of the session, I eventually changed the input assignment of an aux track from 'no input' to 'bus 3-4'. This did NOT crash PT, and it worked just fine. But when I saved & closed the session, reopening that session immediately crashed PT. Other changes don't corrupt the session, but changing track I/O always does. What's going on? I re-installed PT, upgrading from 8.0.0 to 8.0.3. Re-installed M-Audio drivers. Everything else I could think of... Intel Pentium 4 3Ghz, 1GB RAM using a WD firewire drive Last edited by horribleheaven; 03-14-2010 at 11:59 PM. Reason: added more info |
Re: Changing track input/output assignments corrupts session files, causing PT to cra
Still having the same problem. This time with assigning bus inputs to aux tracks. Any ideas?
Import session data causing crash in 8.1 | jval | Pro Tools TDM Systems (Mac) | 5 | 08-19-2010 10:57 PM |
Track levels in session keep changing when the session is re-opened. | Pred80r | Pro Tools TDM Systems (Mac) | 3 | 11-14-2009 01:31 AM |
Quick Time files causing crash. | Droog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-26-2007 07:31 PM |
Changing global rotary assignments? | presence known | ProControl, Control|24, Command|8 | 1 | 04-29-2006 02:01 AM |
