Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 11-26-2020, 08:16 AM
kava kava is offline
Default Atmos Object Automation Phasing problems
I have a large Dolby Atmos Mix Session here Mac PT 2020.11.
I use the Object ON/OFF Automation extensively. But If I set the automation breakpoints exactly at region in/out I hear disturbing phasing of the audio at the end.
I know it's not wise to change Object/Bus in the middle of a region - there will be a small audible silent - ok - but look at my screenshot. the breakpoint is at the end of a FADE OUT. and the whole red area is phasing.
I now try to extend these automations so no phasing is happening but that's not so nice.
any ideas?
Mac Pro 2019 16-Core, 144GB Ram, OS X 10.15
ProTools Ultimate, 2x HDX
NTP Penta720 I/O + 192 HD I/O + SSL Madi Link
Sync HD, Dolby Atmos RMU
S6 - M40 - 32channel.
Filmpost at cosmix studios vienna
http://www.cosmix.at
http://www.tom-kava.com
Old 11-27-2020, 01:19 AM
msw msw is offline
Default Re: Atmos Object Automation Phasing problems
Is the material on the tracks above the same material (it looks like it may be) that is in the bed and at this selection in red you are effectively cross fading between object and bed?
Mark Willsher
www.pin3hot.com
Old 12-01-2020, 10:48 AM
Hi mark,
thanks for taking a look, it‘s in fact the same material - but also an object.
so the 2 objects are not in phase at the fade position.
but it also happens on some objects that don‘t fade into another object or bed.
tom
Dolby Atmos Production Suite (DAPS) bus/bed automation sync issues jamesa5454 Post - Surround - Video 0 03-21-2020 03:29 AM
Object-based automation antonis Post - Surround - Video 22 09-21-2016 07:13 AM
Moving groups of Atmos messes up automation levels? Soundburst Pro Tools 11 3 09-22-2015 08:39 AM
Automation/Object Grabber Bug who Pro Tools TDM Systems (Mac) 2 08-04-2002 08:00 AM
Automation rat's nest w/ Object Grabber thegillman Pro Tools TDM Systems (Mac) 1 10-11-2001 12:18 AM
