Pro Tools first crashing
I am trying to use pro tools first on my home pc (r7 1700, gtx 1070, 16gb hyperx ddr4) and when I launch pro tools for the first time it says that I need to select a play back engine so when I press playback engine the program crashes, no error, Pro Tools just closes. and no holding N doesn't do anything. Thanks in advanced
Re: Pro Tools first crashing
Hi please check what interface is using windows as default playback device . And select other than the one its gonna be using Protools . Also check with asio4all driver if that doesn't work .
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
what do you mean by check what interface is using windows as default playback
Right click the speaker beside to the hour and check this ( image )
Do you have an interface? You need something that Pro Tools can use for I/O. On Windows you need an interface with an ASIO driver, or use ASIO4All with your on board sound card (although that is far from ideal).
Hi All
I too am having the same issue. Asio4All doesnt seem to be doing the trick (windows 10 appears to have a new audio output system, not really allowing you to trick it into using the ASIO driver to launch..unless i am missing something with that?) As mentioned else-where the focusrite scarlett's doesnt seem to fix the problem either.. anyone had positive expeirance of the Behringer UMC22 working in this scenerio? Thanking you! |
Pro Tools Crashing 11.1.2 on OSX 10.5.8 | mzkguy | macOS | 2 | 09-18-2014 05:51 AM |
help pro tools s e crashing | onebloodcujo | Pro Tools SE and Essential (Win) | 0 | 02-11-2012 10:24 PM |
Please help ! Pro tools crashing.... | Grom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-28-2008 12:10 PM |
AAF Crashing Pro Tools | delaplanemusic | Pro Tools TDM Systems (Mac) | 3 | 05-17-2008 12:36 AM |
Pro Tools crashing... | Friday | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-18-2006 07:18 PM |
