Separate drive or partition for audio?
I'm using a digi001 w/PT LE with my g4 dual 1gHz and had a couple of questions. I'm going to get another hard drive.
1. Should I put the audio on a separate drive or just a separate partition? 2.What kind of performance difference will I see between an internal IDE or an internal SCSI? Is it worth it for me to spend the extra cash on the SCSI drive? Thanks
the bytemonster |
Re: Separate drive or partition for audio?
Yes,you should have your OS on a seperate drive for several reasons but that will be a long explanation. Sufice to say yes. Also when you get your new hard disk partition it down to about 4 gig each this will be for your audio only. The reason for the partition is to let your cpu look only through 4 gig at a time instead of say 80 gig.
This makes a big differance. Happy tracking
Tell me you recorded that last pass!!!!! |
Oh and by the way you should be able to get about 3 or 4 songs 24 tracks each @ 24 bit on each of your partitions counting the edits.
SCSI drives are loud clicking devices but transfer data fast. I dont recomend SCSI if your not seperating it from the control room.
Don't buy the SCSI.
You are wasting your money if you are running LE and have a 32 track limit. People on here are running 48 and some report 64 track sessions on modern IDE drives. I own the very expensive, super fast 15K RPM SCSI drives and I don't think I would buy them again - ESPECIALLY if I were not doing more than 32 tracks of audio. DO keep your AUDIO files on a seperate PHYSICAL drive. Feel free to partition THAT drive all you want as the advice from R and R states, just don't try to cheat it by partitioning your one system drive into two - you are just making your hard drive, controller, and OS work twice as hard that way... |
partition my drive or create a separate user for pro tools? | wreckthisplace | General Discussion | 11 | 06-23-2007 03:12 PM |
Upgrading- Hard Drive advice: Partition or Separate? | Paxil | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-05-2007 10:21 AM |
Can PT 5.3 -> 6.4 use FAT partition as audio drive | SixChurchStreet | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-20-2007 11:56 AM |
Separate Hard Drive vs. Partition | joseph halloran | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-09-2004 08:18 PM |
Audio Drive - Partition or not? | Mel2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-02-2000 07:39 AM |
