Old 10-01-2018, 11:30 AM
Robert335c Robert335c is offline
Default How to get Xpand! tambourine single hit
I am not able to get a single hit out of the tambourine in Xpand!- 025, Percussion Tambourine menu (pro Tools 2018.1.0). I get two close hits for a single midi 16th, eighth or quarter note, etc. and am unable to get just a single hit. I've tried turning on the arp settings and setting the rate and mode to 1, Down. Is it possible to get just a single strike to sound from the Xpand! tambourine?
Thank You,
Robert
Old 10-01-2018, 01:59 PM
amagras amagras is offline
Default Re: How to get Xpand! tambourine single hit
Select one of the full percussion presets and find what key correspond to the tambourine.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019
amagrasmusic.com
Old 10-01-2018, 03:48 PM
Thanks. This started me thinking, so I eventually went back, started from scratch, and created a new track. I found the tambourine "single" hit immediately (same 025 Percussion, same Tambourine menu as before).
User error on my part. All that was necessary on the problem first Tambourine track was to turn off the delay plug-in that Pro Tools makes active (along with reverb and chorus) when using a session template midi track, as I was using in this session. I think I grabbed an electric piano track, which came loaded with the delay, and possibly reverb, then renamed it and used it as "Tambourine". I should have checked all the sends levels if I was going to use a "pre loaded" track.
Old 10-01-2018, 03:51 PM
Been there done that!
amagrasmusic.com
Old 10-01-2018, 07:37 PM
Time to create your own session templates(and track presets too)
How to make a "grid" out of a drum track to beat detective a tambourine to. Johnrg Tips & Tricks 16 11-27-2014 04:33 PM
Strike Tambourine Channel 10 help JesseC The Drum Room 0 06-14-2011 01:31 AM
Is there a tambourine in Strike? tooold Virtual Instruments 1 10-03-2010 04:26 PM
Recording a Tambourine Dopamine Tips & Tricks 12 07-23-2002 10:25 PM
Tambourine ufob 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 10-15-2001 05:42 AM
