The Prop-heads lower upgrade to Reason 10 to $99
For those who own some prior version of Reason, I just saw that the P-heads have lowered the upgrade price to 10 to $99. Version 10 added several new rack VI's, and now one of them, Europa, will also come as a separate VST which you can host directly in any DAW with VST hosting. (Use Blue Cat Audio Patchwork for that in Pro Tools myself).
I haven't jumped to 10 yet from 9.5. I'm holding out for when they make some significant improvements in their MIDI implementation, and if they will allow VST hosting with Reason in Rewire mode. If that happens, I'm all in!
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones Owner: Dragon Rock Productions LLC |
Re: The Prop-heads lower upgrade to Reason 10 to $99
I'm tempted as I'm still on version 8 but it's not just the MIDI implementation I'd like to see worked on but the documentation on what they have now. To put it mildly it sucks at least for MIDI. Basic things like how to change MIDI channels so you can trigger more than one Combinator via a single Rewire channel. Or how to have just one path via Rewire that allows both triggering of MIDI notes and a controller like volume (cc7). Right now to do that I have to route to two places in Reason from PT11. Ditch the Combinator and go direct to a synth and a single path into Reason suffices. Until such simple stuff like that gets fixed I'm holding out.
Jack -- Why don't you sign up to beta test it? That way you can see for yourself and decide.
If it's possible and you know then why not tell me what I'm missing? |
"for is the Propheads to fix these basic issues."
WoW.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
I don't know that I ever tried to do that. I'll experiment with it and see. You're right, it does seem like that ought to be possible.
I think I found a workaround that involves doing the multiple MIDI channel assignment inside PT. For instance when using a single Combinator I have to set the MIDI output in the instrument view for the PT instrument track that has Reason on it to two separate paths in Reason (one for the Combinator name mix channel and the other for the Combinator name itself). Elsewise Reason only see the MIDI notes being played in PT and such things as MIDI cc messages like cc7 for volume. Again this is one of those things that the Reason documentation falls down on. |
Whenever I want to use the same MIDI output to play multiple instruments on the Reason rack, I just copy the MIDI track and just change the output assignment for it. Doesn't really take but a few seconds to do.
What I'd like to see the P-heads do is allow MIDI routing on the rack much like we now can do with audio routing. Add MIDI IN/OUT ports on the back of rack VI's and fx, and then we can use virtual MIDI cables to go from anything to anything. Add to that having a MIDI splitter module (like the Spyder for audio) and you can have one MIDI signal in going to multiple outs. I've made the suggestion directly to the p-heads, and even got a response back asking me to clarify a couple things I mentioned. So, I know its on their radar. Whether they do anything with it or not, remains to be seen. But that kind of MIDI improvement would solve most other issues. I've also asked, repeatedly, that VST hosting be allowed when Reason is in slave mode. That alone would be reason enough to upgrade for me. I also know they've talked about adding an additional 4 master knobs on the front of the Combinator. I expect we'll see some major leaps whenever Reason 11 shows up.
Also how about audio from PT into Reason to use the fx in a rack? Imagine using Alligator on PT audio |
That's something else I've brought up more than once. I've asked time and again why Rewire isn't a 2-way street and I've never really received any sort of good explanation why it can't be. If you can route audio FROM the slave to the host, why not the other way round? Its all internal bits and bytes anyways. I tried to figure a way to do it using virtual audio cables. The problem is, that creates a bit of delay, sort of like what happens when you route a MIDI signal from PT to an external hardware synth, and then route the audio from that synth back to PT. Its just the nature of the beast, I guess. The only solution I've come up with for now is to simply export the audio track from PT as a WAV file, and then import that into Reason, add the effect (Alligator, say), and then send the resulting audio back to a PT Aux track for further processing/mixing. A bit cumbersome, but it does work. But, now that the P-heads have begun hosting VSTs, they have also come out with one of their rack VI's as a VST VI as well. Makes me wonder if we might see more of that in the near future. It just might be that you'll be able to have all your Reason VI's and FX as both RE's AND VSTs. Then, we're off and running! It is true that one can use something like Blue Cat Patchwork to do similar stacking and layering with fx and all like you can in a Combinator...but it really isn't as easy, and you really don't have the elegance of control and ease of routing like we see in the Combinator. That is perhaps the most powerful tool out there for sound design, in my opinion.
How about a lower price upgrade? | SteveGarman | Pro Tools 10 | 3 | 10-01-2012 03:20 PM |
Ilok as a movie prop | Tom Graham | Post - Surround - Video | 1 | 07-31-2012 04:10 PM |
Bang Your Heads!!! Drum Heads Thread | Benoni | The Drum Room | 4 | 01-14-2010 03:37 AM |
Heads up on Upgrade? | Euca Design Center | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-16-2007 05:07 PM |
REASON users,, cool free stuff from the Prop's | Homebelly | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 05-18-2004 02:10 PM |
