Old 06-25-2001, 01:30 PM
flytrap flytrap is offline
Default Resetting midi faders very bad!
How do I set the midi faders to "no reset" so that when I stop, the volume doesn't go back to 127?
flytrap
The Acid House
Somerville, NJ
Old 06-25-2001, 02:01 PM
GORILLA GORILLA is offline
Default Re: Resetting midi faders very bad!
Wow, I thought that only happened to me [img]images/icons/shocked.gif[/img] I'd like to know the answer to that too!!
METAL LABS
Old 06-25-2001, 02:06 PM
[Benjamin] [Benjamin] is offline
It sounds like you are doing something wrong: Specifically it sounds like you have written volume automation, and then trying to change the fader afterwards. If you need to change the level of a track after you've written automation, switch to volume view, select the whole lenght of the track (or the length you want to 'trim' automation on), and use the trim tool (pull up-down on the volume "line"). Tip: expand the track for better scaling.
Ben
www.bipeds.tk
Old 06-25-2001, 06:55 PM
Thanks Ben! We'll give that a try [img]images/icons/grin.gif[/img]
METAL LABS
Old 06-25-2001, 09:20 PM
Ben,
No thats not it. I haven't automated anything. This happens with any midi track in any session. It just keeps resetting to full volume after stop is pressed. I know in Logic Audio there is a box you can check in the instrument parameters that says "no reset". And it does just that, so you can keep all of your settings.(I don't know why anyone would want to have the volume reset all the time.....maybe someone knows?)
Is there something I need to check so that it won't reset?
flytrap
The Acid House
Somerville, NJ
How can I use MIDI Faders with Mixer? products7074740 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-22-2009 10:56 PM
midi tracks and the faders... idleave MIDI 0 01-22-2009 07:50 PM
Midi Faders caugusto Pro Tools TDM Systems (Mac) 2 07-29-2008 06:25 AM
USING MIDI FADERS TO CONTROL PRO TOOLS FADERS.... domsound 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-08-2004 07:06 PM
Reset on midi faders flytrap MIDI 0 06-20-2001 05:12 AM
