Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools HDX & HD Native Systems (Win)
Old 01-26-2014, 02:39 AM
adassumpcao adassumpcao is offline
Default HD I/Os, SYNC HD and External Clock
Hi guys,
Sorry to post this on the HDX/HD forum but I didn't find any other suitable place to do it.
I have a setup of 3 HD I/Os and an Antelope OCX external clock serving as the master house clock. I will need to sync an external console to a LTC signal and for that reason I will need the SYNC HD to provide this signal. What's the best way to connect everything and at the same time take full advantage of the Antelope house clock?
- sync the HD I/Os and SYNC HD to external word clock and ignore the LOOP SYNC?
- sync the SYNC HD to external wordclock and the HD I/Os to the LOOP SYNC?
- any other configuration?
Thanks for you time,
Cheers,
Artur
Old 01-26-2014, 07:04 AM
Brandonx1 Brandonx1 is offline
Default Re: HD I/Os, SYNC HD and External Clock
Originally Posted by adassumpcao View Post
- sync the SYNC HD to external wordclock and the HD I/Os to the loop sync
This option
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 01-26-2014, 08:49 AM
Originally Posted by Brandonx1 View Post
This option
Thanks Brandon,
With this option will all the HD I/Os be taking advantge of the Antelope Clock? Is the external clock lock of the SYNC HD good or does it introduce jitter?
Cheers,
Artur
Old 01-26-2014, 09:18 AM
Interesting paper on the subject, but with the oldie 192's
http://www.rcc.ryerson.ca/media/TECH...oInterface.pdf
EDIT:
Another nice paper:
http://www.grimmaudio.com/site/asset...d_clocking.pdf
Old 01-26-2014, 12:24 PM
To get the best clock accuracy I was thinking on connecting both the SYNC HD and all the HD I/Os directly to the External clock. That would get me the most accurate clock on each device if I am correct?
I know that without using the LOOP SYNC i would have to set the clock for each device on a per session basis.
Old 01-27-2014, 12:54 PM
Craig F Craig F is offline
I have seen to may problems by people not using Loop Sync in these situations.
I know the theory of direct connecting each interface but I've seen to much weirdness to ever recommend it
Thank you,
Craig
Old 01-27-2014, 04:10 PM
29CountsNY's Avatar
29CountsNY 29CountsNY is offline
I have a antelope OCX clocking my first 192 and I loop sync the second.
I haven't had any clocking issues what so ever.
And I would think technically the first 192 is passing the antelope signal through the loop sync.
But as I said I have had no issues doing it this way and as Craig F said it is the well documented preferred method.
www.montabonsound.com
www.29counts.com
Pro Tools HD 2019.12 | HD Native PCIe & HD Native Thunderbolt | Lynx Aurora 16 HD | HD I/O | Digi 192 | 2010 Mac Pro 12 Core 3.46ghz | macOS Mojave 10.14.4 | 48 gigs RAM | Tascam DM3200 | Crane Song Avocet II | Antelope Isochrone OCX | Universal Audio Quad & Duo | Waves Mercury + Studio Classics v10 & Abbey Road Collection
Old 01-29-2014, 08:39 AM
So following your suggestion if I understood correctly, in this situation the best would be to have the SYNC HD sync to the Antelope OCX through the 1x/256x signal, and then have all the HD I/Os sync with the SYNC HD through the loop sync?
Cheers,
Artur
Old 01-29-2014, 09:49 AM
yes
Thank you,
Craig
Old 01-30-2014, 01:29 AM
Thanks for the help guys!!
Sync Pro Tools to external MIDI clock nichandle macOS 3 05-03-2013 11:28 AM
External Clock->Sync IO->LoopSync - Does this work? Trailerman Pro Tools TDM Systems (Mac) 5 12-29-2011 12:50 PM
How do U Sync the Mbox2 Pro to external midi clock? rique000 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-28-2008 03:54 PM
Can I run at 96k and sync to external 48k clock? el biciclista Pro Tools TDM Systems (Mac) 4 12-28-2003 08:19 AM
SSD Slave clock and external Sync Inputs Dog BBQ Digidesign Hardware & Software 0 07-12-2002 02:07 PM
