Old 06-04-2019, 02:35 PM
ibanman555 ibanman555 is offline
Default Instrument Track Default MIDI Input Question
This is kind of a two part question regarding using an Instrument Track in Pro Tools. I am using 11.3.1 but I believe this would be the case for many other current versions.
When I create a new instrument track, the view shows the input as "All" and the output assigns properly to the virtual instrument plugin I have assigned to that track. In the MIDI Studio Setup I have created devices, and I can select these devices as inputs on the instrument track. My question regarding this is, how to I set the default input to one of my midi devices and not "All"?
My second question is when a midi input is set to "all", and I record midi, I get duplicate notes. However, if I assign the input to one of my preset midi devices, I do not get the duplicate notes. Why does this happen and is there a way to have an instrument tracks input set to "all" and not have duplicate notes?
Thanks in advance for any insight.
Old 06-06-2019, 03:36 AM
Default Re: Instrument Track Default MIDI Input Question
To answer your first question - can't be done that I can see. Of course you could make a PT session template and work from that.
Second question is a little more complicated and needs some info from you. You talk about 'MIDI devices' - what exactly do you mean - external sound modules, external keyboards? And how is everything connected? If it's standard 5 pin MIDI and you have both the in & out connectors connected you could be dealing with MIDI echo. To cure that go into the setup of each keyboard and turn off 'local on' in it's MIDI setup. Don't do this in OSX but inside each connected keyboard.
MIDI issues can be difficult to fix but not impossible.
Jack
QAPLA!
Old 06-07-2019, 12:14 PM
ChuckS ChuckS is offline
In the newer versions of PT, Track Presets handle what you want. Don't remember exactly when that show up, but there were hacks for earlier versions. Check out the last post in this thread: http://duc.avid.com/showthread.php?t=382372
As far as the double notes - are you playing the same keyboard controller when when the input is set for All and when you select it specifically? With multiple controllers, how are they cabled, what MIDI interface, etc.
PT 2024.3 DP 11.31 VEP 7.x with various VIs
NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11
MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11
MOTU M4 on MacBook Air M2 2023 Sonoma.4.1
Old 06-07-2019, 04:13 PM
My Kurzweil PC2 is connected to a JL Cooper MSB2, along with a MegaDrum interface. The MSB2 just merges the 2 midi controllers into one output that goes into my RME Fireface 800 midi input. No physical loop back on these 5 pin midi cables.
So the only time I get double notes is when instrument track is set to All, not when my Kurzweil midi device is selected as an input. Same goes for the Megadrum.
I am now on PT 2019.5 and will give this another shot to see if it's changed.
Old 06-08-2019, 02:30 AM
So no MIDI cable connected to the Out of the RME to any In on the MSB2? Since your are dealing with one MIDI in, you are using different channels on the controllers, correct? If that's the case, then speculating that you have a split programmed ahead of the merge on the MSB if that's possible and with that scenario the problem would persist in PT 2019.
Anyway, Track Presets are a great addition to PT, plus several other improvements. I think you'll like the upgrade. I own a Kurzweil PC1XL which uses the same patch list as a PC2 with the orchestral ROM - great keyboards.
Question about Instrument/Midi track(s) FT13 macOS 16 12-28-2011 10:49 PM
New Track Input Default Keith Moore Pro Tools TDM Systems (Mac) 2 09-23-2010 08:14 AM
Instrument Track Default View mmf78 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-31-2008 05:05 AM
Instrument track doesn't register midi input in 7.4 Teolin MIDI 3 01-21-2008 03:11 PM
default midi instrument djwilmer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 02-11-2004 11:16 AM
