#21
Re: 12.2.1 Automation Improvements
I realize that the "write to select" behavior needs work, and indeed it should be improved, but not at the expense of a more difficult write to all process.
#22
Frank:
Mac Studio, 32GB, PTHD2022.7, OS 12.5.1, S3, Transport, (EuCon 2022.4.0.78) LIO-8 BlackmagicDesign UltraMonitor3G Reaper 6.66, Fireface UCX MacbookPro M1Pro PTHD2021.12 MacOS12.1 BlackmagicDesign UltraMonitor3G MOTU 24Ao AppleTB3toTB2->AppleTB2->Ethernet->AVB |
#23
When Pro Tools is running and you make a selection, it is only an Edit selection, not a Timeline selection. Automation works on Timeline Selections only. So the "gotcha" this was fixing was only when you had "Suppress 'Write To' Warnings" checked, if you made a selection while the transport was running, and hit "write to all/selection," expecting it to write only to the selection. There are a lot of people who don't want to be warned every time they do an intentional "write to all" (with no selection). Actually pressing the "Write To All" button accidentally if there's no selection of any kind? That is not what this feature was designed to do. If you're afraid of that happening, you should not be checking "Suppress Automation 'Write To" warnings at all. |
#24
Thing is: They call that button "write to selection" not "write to all" (see screen shot above).
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
#25
I am totally with Frank. It is clumsy implementation. Oh you don't want that? Have a nag screen. .....er no thanks. This is lethal in post. Make it an optionr or a pref or two buttons. It's like the N key, does two things that I can't separate The argument that many people want different things is just lame as it ultimately shows Avid find it easier to sit in committees and shrug at its users variance. Get Agile Avid and do something useful. It's just programming, not wheel re-invention!,
cheers Mike Aiton BSc (hons) Audio Consultant, Dubbing Mixer/Sound Designer & Journalist BAFTA member IPS member ---------------------------------------------------------------------- www.mikerophonics.com |
#26
... so anyone using 12.2.1?
anyone experiencing new behaviour in terms of "Write to Selection" (or "write to all" as some call it) I'm just wondering if there is something wrong with my system or Avid forgot to add "coming soon..." thanks!
#27
I have shot a quick video demo - how do I host it?
it works as advertised - which is far from ideal. A small improvement...but not good enough, more homework required Avid
#28
so there should be a message or something that should tell you "hey, you've just messed up your session!"
I guess I have to delete my preferences etc... thanks for checking!
#29
here's the video - sorry about the resolution - was in a hurry
PT 12.2.1 HDX Automation warnings in PT 12_2_1 by mike.aiton, on Flickr
#30
You've labeled the command in question as "Write Automation to Selection" in Pro Tools and S6 shortcut key is labeled "Write to All Sel". Insisting that NO selection is the same as ALL selected is contrary to the naming, contrary to the automation behaviors elsewhere in PT, and counter intuitive. If you want to put in a preference that allows different users such as Rich and Frank to make their personal choice, that would help a lot. Otherwise, please CHANGE the current behavior to make it less dangerous to hours/days/weeks of work. |
Improvements | fsb1 | Artist Series | 0 | 09-25-2010 08:15 AM |
Rtas improvements in PT 8? | grandcoolee | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 11-17-2008 10:15 AM |
Pro tools needs some Improvements | Xbuk | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 03-19-2005 04:52 PM |
Possible improvements to the DUC? | AVGuru1 | General Discussion | 0 | 01-21-2005 12:20 PM |
Digi001 NEEDS IMPROVEMENTS! | mixermon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 42 | 10-25-2001 12:51 AM |
