Audiosuite suddenly not working
I've been editing audio for a documentary for the last week, so instead of using plugin inserts as I would in a music mix I'm printing the eq/noise reduction processing using Audiosuite. It's been working fine until a few minutes ago when I processed a file with Izotope Ozone 4 and it said it had processed the file (the usual progress indicator bar) but the name didn't change (to include the abbreviation for the effect used) and the sound file did not change any. I tried using an extreme effect to see if it was related only to Ozone 4 but not a single Audiosuite plugin does anything, not even the gain plugin.
I did the usual fixit procedure using the Pro Tools Prefs and Database Helper app and first backed up my Digi setup and DAE prefs and then trashed them all and rebooted. After rebooting I created a new one track session and imported a single audio file and same thing, it won't process the file. I guess I could try removing all my plugs except the ones I absolutely need and try that. Anyone have any better ideas? The rig is an HD2 running PT 8.03 on a Mac Pro 8 Core 2.8 with OSX 10.5.8 Thanks Sean |
Re: Audiosuite suddenly not working
See all them buttons at the top of the Audiosuite window? One of them says "Use in Playlist". Press it.
Hah! Thanks Jimmy. Guess that shows just how much I use Audiosuite. Back to normal.
I think that's an easy mistake to make though. I can't think of a single instance of my 10 years of working on Pro Tools when I've not wanted the result in the playlist.
audiosuite has suddenly stopped working?? 7.3.1cs5 xp | bitterkitten | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-16-2008 06:07 PM |
Synthesizer suddenly not working after using M-Box | Haywire | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-26-2006 04:19 AM |
Suddenly not working - DAE error-4 | steve at Your Heaven | Pro Tools TDM Systems (Win) | 5 | 03-21-2006 10:47 PM |
Key commands suddenly controlling Audiosuite menu? | WannabeSQ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 02-16-2006 02:36 PM |
AudioSuite suddenly stopped working- Please Help!! | Capp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 01-01-2005 01:45 PM |
