Old 03-05-2006, 09:04 AM
steve at Your Heaven steve at Your Heaven is offline
Default Suddenly not working - DAE error-4
My HD2 Protools 6.7 won't run (has been fine for over a year). No new hardware, software, or anything.
I used a PT7LE system to record a fairly simple (3 track) session, copied it (all on WinXP) after a Save Session Copy to a v6.7 compatible .pts file. This morning I go to run that in PT6.7r2. Now I get error DAE error-4. No session is loaded, this is while PTools tries to load. It gives the message, I click ok, Protools closes. Rebooting does not help, hard shutdown and turn on does not help.
A few weeks ago, someone sent me a very complex session (40 tracks) the same way (Save Copy to .pts from a v7LE system) which caused no problems and worked fine.
I removed PT6.7, re-installed it, I got the same error message just after it re-authorized a few plugins.
I have heard of deleting preferences, etc. Any suggestions, or does anyone know anything about this?
Thanks
steve
Your Heaven
Old 03-05-2006, 03:15 PM
Default Re: Suddenly not working - DAE error-4
Troubleshooting steps for XP
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 03-05-2006, 10:35 PM
Bless you, Rail Jon, that got me working again.
steve
Your Heaven
Old 03-05-2006, 11:27 PM
Hmmmm, but now it's back.
steve
Your Heaven
Old 03-06-2006, 12:00 AM
If your prefs or databases are constantly becoming corrupt.. it's time to check your hard drive or try reinstalling Pro Tools (or both).
Rail
Platinum Samples
Old 03-21-2006, 11:47 PM
Been crazy busy, tonight my first break in three weeks. I wanted to say thanks to Rail, this is the first I've had to check the board in a while.
It was definitely a prefs/database problem, and complicated by using the same session on different drives (while shifting between machines, etc.).
steve
Your Heaven
Suddenly tranzport is not working with pro tools 10.3 shamanrock Windows 0 10-31-2012 12:00 AM
Audiosuite suddenly not working ampnerd Pro Tools TDM Systems (Mac) 3 08-10-2010 07:49 AM
MBox2 Pro suddenly not working ritaM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-30-2010 03:47 PM
Synthesizer suddenly not working after using M-Box Haywire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-26-2006 05:19 AM
PT LE Bussing Suddenly not working saltobello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-12-2005 11:41 AM
