Old 12-11-2005, 08:33 PM
saltobello saltobello is offline
Default PT LE Bussing Suddenly not working
I’m running PT LE 6.4 on a Mac, running OS 10.3.9. I also have a Baby HUI.
I have a simple mix set-up that’s been working without a hitch until just a couple of minutes ago:
-My main stereo tracks are subbed out to Bus 1-2
-My record track is getting it’s input from Bus 1-2
Simple, right? Well, it’s worked like a charm. I record enable my record track and mix away.
Well, suddenly, after quitting out for a break and re-booting PT, I now get no level on my record track. The only sign of life is when I hit the space bar to stop playing; then I get a pop on the channel which spikes the levels.
I’ve trashed my preferences, re-booted, created new tracks, and confirmed that there’s sound coming out of my speakers. In fact, when I simply play regions on the record track, it sounds fine.
Any suggestions?
Thanks!!
Stephen
Mac OSX10.3.4
PT LE 6.4cs7
mBox
Old 12-11-2005, 08:44 PM
Matt82au Matt82au is offline
Default Re: PT LE Bussing Suddenly not working
i've had this issue before, are you running an mbox 1? i think i disabled the sends and re-enabled them, rebooted pro tools, all that crapping around stuff that shouldnt matter but seems to fix it. eventually it just started working again. one of those ghost things. all i can suggest is make sure you have the latest versions, maybe a clean install? (ie no real answer) and wish you luck! i remember it was just my system not doing something it should!!?? who woulda thought?
Matt Perrott
Sound Designer and Engineer
Sydney, Australia
Old 12-12-2005, 11:41 AM
DigiTechSupt's Avatar
Try toggling between 'Auto Input' and 'Input Only' monitoring.
Also, you could try creating a new session and importing session data from this session, in case of session corruption.
Avid Audio Tech Support
Support FAQ
Audiosuite suddenly not working ampnerd Pro Tools TDM Systems (Mac) 3 08-10-2010 07:49 AM
MBox2 Pro suddenly not working ritaM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-30-2010 03:47 PM
Suddenly not working - DAE error-4 steve at Your Heaven Pro Tools TDM Systems (Win) 5 03-21-2006 11:47 PM
bussing to audio track for recording not working bowserlm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-15-2005 02:18 PM
bussing stops working babyseal Pro Tools TDM Systems (Mac) 1 08-14-2002 02:15 AM
