Old 01-19-2015, 02:21 PM
heabow heabow is offline
Default PT Crashes and crashes again... Help needed!
For some reason PT10 crashes several times a day now. It used to work fine tho. When I work on a MIDI part, the edit window sometimes reacts in a weird way, like flashes or is totally black (depends on the zoom actually). Otherwise it crashes even if I don't work on MIDI stuff. I feel it is not stable anymore and I have a lot of work I really need help.
Thank you!
Specs: iMac 27" 3.5gHz Intel Core i7 32Go RAM / OSX 10.8.5 / SSD external device. PT 10.3.7
Crash reports: http://we.tl/WQcrXIPIXl
Old 01-20-2015, 06:55 AM
citysoundman citysoundman is offline
Default Re: PT Crashes and crashes again... Help needed!
Have you trashed all the PT preferences? You can use this handy utility http://duc.avid.com/showthread.php?t...light=PT+prefs
Bob Kirschner
NYC-based Audio Post Mixer/Sound Designer
bobkirschner.com
Old 01-20-2015, 07:03 AM
Yes I have. I have to do permission repair tho.
Old 01-20-2015, 12:15 PM
PT seems to crash when MIDI tracks are in the session. I had DAE 7054 once also. Could someone read the crash reports to put some light on please?
Old 01-20-2015, 05:56 PM
Post Re: PT Crashes and crashes again... Help needed!
One of those crashes is related to FireWire. This could be a problem with your audio interface, the cable connecting it to your iMac, or the driver software.
Old 01-23-2015, 02:44 AM
Anyone else?
Pro Tools crashes when running a few plugins - help needed deanaladay macOS 7 11-15-2011 01:45 PM
Please Help- PT 8.o Crashes ModernRPM 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-21-2009 07:48 PM
PT Crashes help please? hgent Pro Tools M-Powered (Win) 8 07-19-2006 03:31 PM
Crashes crashes and crashes!!!! BoRiZ KukoBa Pro Tools TDM Systems (Mac) 5 09-18-2003 12:54 AM
Please Help Someone With Crashes M2E Pro Tools TDM Systems (Mac) 0 09-12-2003 06:33 PM
