Moving marker selects all tracks?
Hey, I think I've accidently made Pro Tools mad at me.
For some reason, when I move the marker, all tracks gets selected. Really annoying. How do I disable this? |
Re: Moving marker selects all tracks?
Not sure if it's a called a marker. That play marker (that guideline that's moving forward when the song is played)
That's not a marker, and it sounds like its behaving normally. What are you trying to do? Generally, you would choose the smart tool and simply click with the I tool(smart tool with the cursor hovering in the upper half on any track). Click and playback would start from that point when you hit the spacebar. Another possibility, maybe the ALL group is selected. Have learned about groups yet? Tiny arrow pointing to the left, in the lower left corner. Click on it to open/close a column that shows tracks in the upper pane and groups in the lower pane. If there is a group named ALL, and if its highlighted, click on it to UNhighlight it and try again.
I know about groups. It's not that, though it behaivs almost like the all group is selected. when I click anywhere in the edit area all tracks gets selected. I don't want that!
If its not a group, then is it possible the Alt key is stuck on your keyboard? I have never seen this happen unless a group is enabled.
The alt key is not stuck, it's working like normal in all other software. I have no idea why pro tools do this to me..
I know you say it's not groups, but suspend all groups anyway and see if it still does it.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
I've already done that. Is there some sort of key comand for this thing i am experiencing?
Trashing prefs and database files is worth a try for any odd behavior(of Pro Tools)
Pro Tools selects all tracks in a region rather than one | Vectivus | Pro Tools M-Powered (Win) | 4 | 09-24-2009 10:19 AM |
Can't select just on track, selects all tracks | dwilliam | Pro Tools M-Powered (Win) | 5 | 01-11-2007 09:37 AM |
Marker slippage - moving markers | bignick | Tips & Tricks | 5 | 07-04-2006 01:03 AM |
Moving insertion point to next marker? | IO Composer | Pro Tools TDM Systems (Mac) | 2 | 11-15-2005 12:21 PM |
Moving a marker with its associate region | yotam agam | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-05-2004 02:49 AM |
