  #101
Old 11-04-2020, 12:45 PM
Pete Gates Pete Gates is offline
Default Re: free ADR cueing software
2.11.32 is up
"Rebuild Clips in PT" added in the main page. This was written for a particular user here whose Pro Tools session had corrupted, losing all his ADR cues. He had the backup PG PT Session JSON file though and wanted a way to recreate the cues in Pro Tools.
It will create region groups of the currently selected PG PT Session track on the currently selected track in Pro Tools (can be any name track, doesn't have to match the original track name. It also doesn't clear the track so you can merge the clips into existing track contents. Both these things mean you can be a bit 'creative' with it maybe). Tested on Mac but not PC yet as I don't currently have a PC running Pro Tools.
Once this has been "battle hardened" I'll add more features - such as bulk group creation from text files/EDLs etc.
Pete
  #102
Old 11-09-2020, 12:22 PM
I've had to move the download hosting of my software (for reasons that are way too boring to explain). To match the PT Prefs software, they're now on Dropbox.
Dropbox / PG PT Session MacOS 10.11-11.5 version
(please note: this release requires MacOS with Metal graphics support, for older versions of MacOS use the version below)
Dropbox / PG PT Session Mac version ONLY FOR MacOS 10.8, 10.9 & 10.10 (MOUNTAIN LION, MAVERICKS & YOSEMITE)
Dropbox / PG PT Session PC version
Cheers,
Pete
  #103
Old 03-11-2021, 01:08 PM
2.13.1 is now up.
Now has significantly faster direct Pro Tools session import, especially on large sessions.
There has been a fair bit of internal tidying up work. This is to pave the way for new features over the summer.
It has been tested on MacOS 10.8.5 and 11.2.3, it's quite hard to maintain support across such a range of operating system generations, probably won't be able to do it for much longer.
Cheers,
Pete
  #104
Old 05-22-2021, 02:04 PM
New version up 2.13.21
Minor feature is that you can select 3 different sizes for the Script font.
Another feature that is useful for ADR (and non-ADR use) is the ability to create markers for the start of every clip on the selected track. So you can create a marker for every ADR cue or any other type of audio clip/region group.
Pete
  #105
Old 05-22-2021, 05:08 PM
gives's Avatar
gives gives is offline
Thanks Pete! You ARE the man! for a lot of us-:). G
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.6, DP 11.3.1, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS
  #106
Old 07-19-2021, 11:19 AM
Thanks, very kind of you to say.
2.14.1 is up, 2.14.X will be the last series to support MacOS 10.8.5 (amazingly there are editors still on this, I guess if it works and does all you need and you're earning on it... ) So anyone still on 10.8.5 get requests/bug reports in or you'll get stranded. Will be moving to minimum requirement of 10.9 or maybe even 10.10 later this year.
2.14.1 is a weird release, it doesn't visibly offer much but there's a lot of refactoring/tidying up in it. This is in preparation for some new features.
The obvious new button is Backup, this saves the loaded session in the standard PG PT Session JSON backup format (without exporting all the PDF etc files). This is useful if you've done any editing withing the software that isn't in the Pro Tools session. Also, it's now an option whether to embed fonts - in Prefs (formerly called Export Options), PDFs without fonts embedded are much smaller but potentially less compatible cross-platform (which is why it's an Option).
Pete
  #107
Old 07-19-2021, 01:06 PM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
Thanks!
For some reason the windows version link of PGPTWAVChecker isn't working.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
  #108
Old 07-19-2021, 01:29 PM
Sorry about that. I'll fix it tonight.
Pete
  #109
Old 07-19-2021, 01:55 PM
Fixed
  #110
Old 07-22-2021, 05:21 AM
I've had to split the Mountain Lion version off due to a bug fix for later versions of MacOS that causes a big issue with Mountain Lion. There are now two different downloads available - only use the Mountain Lion specific one with Mountain Lion, for later versions of MacOS use the normal download.
(ps the Mountain Lion version is still functionally the same as the other version)
Cheers,
Pete
HTML code is On
From MAc to PC: ADR Cueing software and soundminer gsilbers Post - Surround - Video 5 11-10-2011 10:42 AM
Cueing Mac and Xp pro tools le 7! plz read DukeDiddy89 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-16-2011 12:46 PM
ADR - cueing-beeps... clusterer Post - Surround - Video 29 02-17-2006 05:52 AM
Cueing Headphone Mixes - how?? mixit 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 12-20-2004 05:52 PM
Error Cueing DV Machine InnoForm Media Pro Tools TDM Systems (Mac) 6 05-09-2004 09:56 AM
