Old 08-06-2004, 09:44 PM
s0nguy s0nguy is offline
Default C24 Monitor Section
Is it just me or do you guys think the monitor section of the C24 sounds terrible?
I did three tests today....out of my UA2192 straight to the Mackie Hr824s...then out of the 2192 through a 1202VLZ mixer to monitors....then from 2192 through C24 to monitors....
Even the Mackie mixer sounded better than the C24. I am currently looking for a solution that would allow me to adjust the volume directly from the 2192.....I can't deal with the loss of clarity anymore.
-S0nguy
Old 08-08-2004, 10:32 AM
Default Re: C24 Monitor Section
I guess everyone here is using the monitor section and not really hearing what it going on in the mix?
-S0nguy
Old 08-09-2004, 01:44 AM
steins steins is offline
I'm using the monitor section, and I believe I'm hearing what's going on in my mixes ;-). The sound quality could have been better though, and I'm seriously considering a CraneSong Avocet myself.
IMO, the C24 monitor section does what it is supposed to, but like all other things, it can be improved.
Stein Tore
Stein Tore Sønsteli
My private mixing room: Pro Tools Ultimate 2020.11 (HDN), Mac Pro 5.1 OS X High Sierra, Avid I/O's, D-Command ES 8-fader.
Main studio at work: Pro Tools Ultimate 2020.11 (HDX-1), Mac Mini 2018 OS X Mojave, RedNet/Dante I/O's, Avid S6 24-fader.
Audio editing suites at work: Pro Tools Ultimate 2020.11 (HDN), Mac Pro 6.1, OS X Mojave, Avid Omni, Artist Series control surfaces.
Old 08-09-2004, 07:29 AM
Stein Tore
When you puit the Avocet on your 2 mix, you are going to weep.
-S0nguy
Old 08-09-2004, 08:02 AM
I'll also be weeping all the way to the bank. That's a lot of weeping for one day, but I look forward to it
Stein Tore
Stein Tore Sønsteli
Old 08-09-2004, 09:20 PM
Imagine Imagine is offline
Why not get a Benchmark DAC1, and if you have more than a set of monitors, the Switch Witch does the trick.
Dean
Old 08-10-2004, 08:48 AM
I have hit upon the solution for me. I ordered the NHT PVC for volume control. I will use the C24 for my Cue mixes..........no biggie there......
-S0nguy
Monitor Section Hanswurstlsepp Avid S6 36 06-06-2014 03:52 PM
003r monitor section hotstuff 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 26 04-17-2010 04:57 AM
Distortion in monitor section subwoof ICON & C|24 1 06-06-2007 01:12 PM
PC monitor section nworb ecnal ProControl, Control|24, Command|8 0 03-15-2002 12:33 PM
C-24 Monitor section Rollerex ICON & C|24 30 09-18-2001 11:18 AM
