List of default Pro Tools preferences?
Due to some trouble (Pro Tools being unresponsive when launched until I force quit and relaunch; Pro Tools QuickTime Server seems to always be unresponsive, but I can still run Pro Tools), I'm considering pulling out my Pro Tools preferences file, and starting from scratch. Going forward, I'd like to have a (text, etc.) file listing Pro Tools preferences by category, showing preference defaults, and any changes I make.
1) Is there a (text / web) list of Pro Tools default preferences? On a related note, it appears the preferences file for v. 2018 is: ~/Preferences/Avid/Pro Tools/Pro Tools Prefs That has a modify date of the last date I used PT. 2) That's the one I should remove, correct? I have a Pro Tools Prefs file in ~/Preferences/ , but last modified in 2014, so I suspect that is where an earlier version of PT stored it. thanks |
Re: List of default Pro Tools preferences?
Try using Guitardom's "Trasher" app. It may help. You can find it here. http://www.pro-tools-pc.us/category-s/1814.htm
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
That's for older versions of Pro Tools. Save yourself some hassle and download my free utility for deleting Pro Tools preference files (there are more than those ones to get rid of!). Cheers, Pete |
Not sure if it will benefit you in this instance, but an OSX thing that I use sometimes is the key combo command-shift-3. It will throw a screen capture on your desktop. you can then drag it to a folder of saved things or whatever. It definitely comes in handy at times, if you can remember to use it.
Pete, do you have list of which it deletes? I want to document my current settings before deleting. thanks!
Good one, thanks. I also use command-shift-4, then if I'm trying to capture just a window, put the cursor over the window, and hit the spacebar. It captures just the window I'm after (in the clipboard), and I don't have to drag around the window. Cool thing I learned today, is that even works with a window that is partially obscured. Click on part of the window, press the spacebar, and the entire window is captured.
I don't currently but you can backup your settings before resetting them. Cheers, Pete |
Customizing Plugin List ; Beyond Preferences->Display | adam79 | Pro Tools 12 | 1 | 01-13-2018 06:01 AM |
New PT Sessions default to different preferences and settings. Help Needed. | GeorgeRiley81 | macOS | 0 | 12-09-2015 04:45 AM |
Pro Tools 9 Default Outputs and Solo Preferences Not Saving | mindsmack | macOS | 4 | 05-19-2011 07:20 AM |
003 is not in the hardware list in mac sound system preferences. | ritualbeatingsystem | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-08-2009 03:16 AM |
How to Reset Preferences to Default? | Vervus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-26-2008 07:44 PM |
