Old 04-08-2018, 04:13 PM
tamtamstudio tamtamstudio is offline
Default Bounce to disk offline error on 2018.4! take care, use online instead!
Hi all, today I'm gonna crazy.
I tried many times to bounce to disk in offline mode. (HDX)
The result file is the rendered mix with a second mixdown (copy) merged above, less louder but it confusing all the mix! (of course)
With bounce to disk in online mode not appear.
Some months ago I received a strange phase shift on channels with indoor DSP plugin (audioease), bouncing to disk in offline.
Fortunately, the guys at audioease told me I can bounce to disk in offline, only if I switch (was a PT/Indoor bug) to Native and that solved problems.
Now I tried to switch all plugins of the session in native, just in case, but no difference at all.
Take care and double check your bounces, it seems a real bug.
Anybody reported something like that?
Corrado Magalotti
Tam Tam Recording studio
Old 04-09-2018, 07:38 AM
Default Re: Bounce to disk offline error on 2018.4! take care, use online instead!
here a couple of snippets of the problem:
Online Bounce:
https://www.dropbox.com/preview/test....m4a?role=work
offline bounce:
Corrado Magalotti
Old 04-23-2018, 08:45 AM
jeam25's Avatar
jeam25 jeam25 is offline
Hi friend not happening on Ultimate and non Ultimate . Did you resolve it ?
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 04-23-2018, 10:33 PM
psycho_monkey psycho_monkey is offline
I'm also seeing the same thing. Offline bounce doesn't appear to be taking into account delay compensation or similar.
I'm running Ultimate 2018.4. 2018.3 was fine as far as I can remember.
Online printing is fine. Offline goes out of sync. On both HDX and internal audio. high Sierra (native) and El Cap (HDX).
It's definitely a new bug introduced under 2018.4
Old 04-24-2018, 12:58 PM
reflexson reflexson is offline
I’m having the same issues. Hdx sierra. Ultimate
Paul Cox
www.226recordings.com
Old 04-24-2018, 01:32 PM
Eric Seaberg's Avatar
Eric Seaberg Eric Seaberg is offline
I just checked some of the last sessions I did offline and they're all good... 7-stereo and 2-mono stems all bounced at the same time. All levels look good and everything's in sync. I don't use delay-compensation, however. Maybe I'll try it again with DC enabled...
OS 10.12.6 (Sierra)
ProTools 2018.4.0 HD Native
Mac Pro Tower 2x2.4GHz 6-core with 40GB RAM
Eric Seaberg • San Diego, CA
A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S.
Old 04-24-2018, 02:08 PM
Guy McDude Guy McDude is offline
Same here.
All kinds of craziness.
Real time bounces only from here on out.
Not very “ultimate” if you ask me....
Shame.
EDIT..
Can anyone on 2018.3 verify solid offline commit/ bounces with native and DSP plugs?
I was able to get 2018.4 to kinda work in offline, but only with DSP plugs.
thanks
Best,
Sean
Sean McDonald
Red Medicine Recording LLC
Sofa King Music Services
http://www.seanmcdonald.com
Old 04-24-2018, 07:54 PM
I reverted back to 2018.3, it did not solve the issue here.
Best,
Sean
Sean McDonald
Old 04-25-2018, 11:23 AM
Also, another compensation bug, pro tools will not compensate correctly for any effect that receives a midi input(stutter edit, reaktor etc) on an aux or instrument track. Sucks. Think this one is hdx only.
Paul Cox
Old 04-26-2018, 02:22 PM
Henning Svoren Henning Svoren is offline
This bug existed long before 2018.4, both HDX and HD Native, unfortunately.
www.oceansound.no
PT 12 offline vs online bounce AntonFAudioDesign Pro Tools 12 12 04-05-2015 04:51 PM
CPU errors during online bounce Dynamixaled Pro Tools 11 5 02-08-2015 12:05 PM
Can't reach online customer support. Getting error message songwritergrl Getting Started 1 10-14-2014 09:49 PM
Online Product Registration error message slackaudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-28-2007 09:50 AM
online digistudio is the only reason pt 5.2 exists?and no pt le on digistudio(online) raape 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 14 11-11-2001 06:51 AM
