newbie, can't hear midi keyboard
Hi there!
So yes, I'm such a newbie with Pro Tools, just bought an M-Audio fast track, which included Pro tools SE, I've been having fun doing some recordings of real instruments, but then I got a little keyboard (keystation mini 32) and I can't find the way to hear it on my headphones (those are plugged to the fast track interface), I got an instrument track: then I start recording and the track shows that is recording notes, but I can't hear anything, not in my computer or headphones, here the settings I tried for it (it only gives me one xpand option): and nothing, I've looked through tutorials, but they only show about recording not about hearing it, also most of the tutorials are for normal versions of Pro Tools, not the SE, I'm probably missing something silly, as again, I'm new at this, so if somebody could help me I would be soooooo happy Last edited by cRistrings; 10-13-2013 at 07:33 AM. |
Re: newbie, can't hear midi keyboard
Hey Craig F, it says grand piano, but I've changed that to others and still no luck, thanks for your quick reply btw
I also tried midi external devices and nope not the grand piano (or other VI) or midi external devices give me any sound, it records them but I can't hear anything Last edited by cRistrings; 10-12-2013 at 09:14 PM. |
Also have you defaulted all your i/o settings and tried again? Chris
yes, I've clicked recording on the track, then play the keyboard and nothing. then the track recording and also the main recording button on the top without the play one, played the keyboard and no sound, only when i actuallly record (with play button as well) i can see it on the track that i'm playing but i can't hear it in anyway, now, not sure how to default the i/o settings as my pro tools SE doesn't has a "settings" menu |
Have you selected output on Instrument & Master track to 'Main out L/R'?
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
Just wondering if you managed to sort this out as I'm having the same issue. MIDI virtual instrument can be seen registering output in mix window but there is no actual sound being generated.
Cheers.
Any assistance is greatly appreciated, Thunderbird. |
Try starting a new project and creat a new instrument track and select Mini Grand piano. This worked for me. I don't know why it wouldn't work in my previous session. At least this sorts out part of the problem.
Can't monitor/hear midi by highlighting the midi track and playing the keyboard | jgagne1 | macOS | 4 | 01-18-2015 08:42 PM |
I have a midi keyboard and electric drum kit...I can only hear drum's midi playback | thrice506 | MIDI | 0 | 02-09-2014 11:18 AM |
Newbie needs help setting with midi keyboard | planetmerc | MIDI | 4 | 02-28-2010 11:13 AM |
Newbie question - can't hear clicks (MIDI) | harmonist34 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-28-2007 05:46 PM |
