Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
Old 08-11-2015, 01:08 PM
ptauger ptauger is offline
Default Fast Track Ultra and Windows 10
I just upgraded to Win10. I have a Fast Track Ultra that worked perfectly under Win7. However, under Win10, the system will not recognize input at any sample rate over 44100. Apparently, this is a sufficiently common problem that it's been reported by others.
Windows Support's suggestion was to install in compatibility mode for Win7 o Win8 and disable other sound devices. I tried all of this, but still no joy.
Will Avid be releasing a compatible driver? Is there a work around for this?
Thanks.
Old 08-12-2015, 07:04 AM
JoelG's Avatar
JoelG JoelG is offline
Default Re: Fast Track Ultra and Windows 10
The FTU should be getting support until 2018, so in my opinion it should get driver updates:
http://avid.force.com/pkb/articles/e...-support-dates
But keep in mind that at this time Windows 10 is not qualified for either Pro Tools or and Avid devices. http://avid.force.com/pkb/articles/e...-Avid-Products (that said, I'm working fine with Win 10)
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 09-13-2015, 09:23 AM
Here's how I got my Fast Track Ultra to work under Windows 10:
In the BIOS of the computer, disable on-board Realtek HD Audio (or, if you have an add-on card, don't use it).
In Services, disable all Realtek Audio services.
After that, my Fast Track Ultra worked fine. Note that, to set the bit-depth and sample rate, you must do it in the Fast Track Ultra app in the Control Panel -- you will not be able to do it in the Sound app in control panel.
Old 01-28-2016, 12:18 PM
Jonnie1597 Jonnie1597 is offline
Could you possibly post a step by step process on how you were able to get your fast track ultra working with Windows 10. I would greatly appreciate it.
Fast Track Ultra 8R Windows 10 drivers? Amechan FireWire & USB Audio Interfaces (Win) 9 11-15-2015 11:52 PM
Fast Track Ultra Windows crashes ducknoir FireWire & USB Audio Interfaces (Win) 0 06-15-2015 05:51 PM
Fast Track Ultra Driver 6.1.10 Won't Install Windows 8.1 manonash FireWire & USB Audio Interfaces (Win) 0 11-23-2014 01:03 PM
Fast Track Ultra on Windows 8 x64 mcrooney FireWire & USB Audio Interfaces (Win) 4 04-27-2014 05:08 AM
Fast Track Ultra with Pro Tools 7 M- Powered for Windows NERO1 Pro Tools M-Powered (Win) 0 02-25-2008 09:48 AM
