Re: Mbox 3 Pro on Windows 8 randomly going mute
oh my !!!
where to start.. i had the same problem, was using very expensive gigabyte z87 oc force motherboard, with via firewire chipset pci ex card and couldn't even play audio for 2 secs on youtube. was using driver 1.1.9. so went only found out via chipset not good, bought siig TI chipset card for 60. same problem. then i changed motherboard to asus z87 plus and voila!!!! everything started working. had same problem with asus z87 and via chipset firewire card. no idea why gigabyte and siig TI card didnt work. spend two days in a row to trouble shoot. and from now onward never gonna touch avid hardware. please buy quality hardware with good driver support. using windows 8.1 update 1 driver 1.1.9 siig TI firewire card. mbox pro gen 3 if anybody else has audio drops / crackling sound/ no audio/ same problem please try to swap Motherboard. thanks. |
I have the same problem on Windows 7 with an MBox Pro 2. I have a dual 8-core Mac Pro and I have absolutely no problems under Mac OS, but it drops out all the time in Windows 7.
Literally, I just went to a YouTube video and it was playing normally. I hit Back on my browser because I changed my mind about the video that was playing. Then I immediately changed my mind again and clicked Forward and the sound was gone. What the hell could cause that? |
finally solved the problem but not completely.(there were glitches or pops and sometimes completely loosing sound in my daw while i browse windows or use other apps)
i went to control pannel-->hardware and sound-->manage audio devices. speakers avid mbox pro was the the default device so i changed the default device to realtek digital output. now i can work without loosing sound in my daw but i will not be able to hear the output from other windows apps such as windows media player or youtube. for that i have to set mbox as default device again. But now i can work without any issues or loosing sound. |
Switched from mac to win 8 and have the same random mutes issue! Just shocked! Searching for solution...
I don't think this is a problem related to windows or other applications using the mbox. I do think using the mbox as your default or communications playback devices is a mistake but not the cause of the sound going mute.
I also have a windows 8 setup, mbox 3. However I use a totally seperate set of speakers for my youtube and windows related activities. Yet I still will have the issue where the sound will go completely mute while working in a session. You close pro tools and re open and then it starts to work again. Crazy smh I've seen funny things happen when low latency monitor is turned on in terms of sound going mute. You could uncheck that to see if it makes a difference
PC Dell XPS 8700, i7 CPU @ 3.40GHz, 4 Core(s), 8 Logical Processor(s). 32 GB RAM, Windows 8.1 Recording Pro-Tools 12.4. Mbox Pro 3 (Driver 1.1.10) FireWire CPU Interface w/ Presonus FADERPORT. |
#16
I had this problem, what fixed it for me was making sure line out 1/2 is set to 16bit for multimedia PC stuff. And 24 bit for pro tools. It seems the mbox 3 Pro doesn't like it when your trying to play compressed audio at 24 bit.
Mbox Loud static white noise bursting randomly HELP PLSS | gizmoholm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-20-2011 11:01 AM |
Pro Tools 9 randomly freezes my system. Windows 7 | shimmyshimmy | Windows | 9 | 09-20-2011 11:45 AM |
MBox Shuts off Randomly and Feeds Back | thespacebandito | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-12-2008 05:17 PM |
Mbox 2 driver re-install randomly whenever MBox plugged in | Herkimer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-25-2008 08:22 AM |
Windows XP Hangs Randomly | Riad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 08-08-2003 05:33 AM |
