Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Win)
  #121
Old 04-08-2014, 09:33 AM
Wcutta Wcutta is offline
Default Re: "Tuner" and internal "DSP" doesn't work on Mbox 3 Pro
Any update on the windows driver? Any chance we'll be seeing it released before June?
  #122
Old 04-14-2014, 01:21 AM
AndreN AndreN is offline
Sorry to report that the latest update does NOT fix my "tuner/DSP not working" issue. It sucks.
  #123
Old 05-01-2014, 11:06 AM
Dexxy's Avatar
Dexxy Dexxy is offline
After all you've done a good driver for mboxpro version 1.1.10 has corrected the problem.
Thank you.
  #124
Old 05-01-2014, 01:04 PM
guatamas guatamas is offline
Thank you.
Yes!! Thank you Avid I now have my tuner and DSP working again
  #125
Old 05-04-2014, 04:32 PM
Partially worked for me. Room 2, Hall 1, and Plate still dont work (I get alot of distortion) and Hall 2 distorts initially when switched to but the tuner and every other setting works fine. Maybe reinstalling the driver will do the trick
  #126
Old 05-16-2014, 05:57 AM
Delianguy Delianguy is offline
So, I have a mac OS 10.7.5, am using PT9.
My current MBox 3pro driver is 1.1.3 with firmware 1.0.3. All of the fixes in the new firmware update are what I need as I've had the "DSP" problem for a couple of years now after doing a previous driver update. The last time I did a driver update, it messed up my mbox because the drivers were for PT 11. I had to uninstall and re-install the earlier driver to work with PT9. Here's the question:
If I upgrade to the new driver to get the new firmware fixes, is that going to screw up my PT9 functionality again? Is there a way to get ONLY the firmware upgrade without the driver upgrade? Of course, if anyone here is using PT 9 and Mac Lion and has upgprade to the new driver without any issues, please let me know. I'm a little hesitant.
Thanks,
Nick
P.S. Did the upgrade fix your DSP issue?
  #127
Old 05-23-2014, 11:11 AM
serio serio is offline
I did it but I didn't use my main computer for the update. That way i wouldn't have to revert anything on it, just plug in the updated mbox.
works fine so far...
http://duc.avid.com/showpost.php?p=2148586&postcount=84
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ
  #128
Old 06-14-2014, 07:53 AM
AudioboyProductions AudioboyProductions is offline
Windows 7 here... just installed the new update and I'm glad to say it fixed my problem. DSP works again. I was half expecting the update to screw the MBox up even more and I don't think I'll be messing with any further updates.
Why it has taken so long to release a fix for this is beyond me. Terrible customer service.
  #129
Old 06-14-2014, 08:39 AM
Update: DSP works fine but now the audio is cutting out.
Great job Avid! Shall be avoiding Avid products like the plague.
  #130
Old 06-20-2014, 03:25 AM
In case anyone else has the same problem with audio cutting out with the latest drivers (1.1.10), I got it working again by uninstalling them and using the older driver (1.0.19).
Essentially I used the newer driver to update the firmware which in turn fixed the DSP problem. Then I had to roll back to the old driver to stop the audio cutting out.
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? bashville Pro Tools 10 5 03-23-2013 03:04 PM
3tuner" and internal "DSP" doesn't work on Mbox Pro (3G) luckydjacks Windows 0 12-31-2012 04:40 AM
Toggle Track view ("Opt"+"-") doesn't work LukeFromBerlin macOS 3 04-01-2012 04:43 AM
hardware buttons for "preview", "capture" and "punch" evs Post - Surround - Video 1 12-06-2010 12:28 PM
