BFD....Triggers?
So, being VERY new to midi. Can I use a say a Roland TD5 drum kit as a trigger for BFD? And if so, can I isolate each track (i.e. track 1 Kick/ 2 snare...and so on)? After seeing so much talk about this, I'm very interested in getting this software.
Thanks for any help. Jeff |
Re: BFD....Triggers?
bump /\
I can't answer for the ROLAND (but I believe the answer is yes), I am using a Yamaha DTXPRESS III kit and it triggers absolutely like a dream. I totally fell in love with the sounds of BFD.
Here is a little demo example I did with the kit/BFD http://www.keithlubrant.com/_tunes/feb_day.mp3 The song is going to be on my next CD (which I am currently recording..but with live drums!). I use BFD for quick demos and jingles. Thanks, Keith |
Thanks for the response Keith. Sounds great. How difficult is it to program BFD with your kit?
piece of cake...I just had to link each pad (through the kit brain) to correspond to the GM# that bfd supplies for each of their samples. It honestly wasn't that tough.
The first time I had it hooked up and the monitors blazing...it sounded incredible. Plus you can either send to to a two track mix or bust out each pad to it's on track, which gives you even MORE flexibility to EQ/compress to taste. The recording was just the 2 track version. |
thanks keith, I think I'll bpick up bfd later thbis week. Do byou have any other sound clips I could here?
Jeff |
none yet...I just picked it up myself!
I have a TD-5 brain with BFD. I use the dual trigger cymbals and a Hart Dynamics snare drum. The rest of the pads are typical hard rubber. I have not had ANY luck mapping the triggers of this brain to BFD. There is a "learn" function, but no luck. I can get the kick, snare and toms mapped, but the dual trigger cymbals and hi hat have not worked out to well.
I like BFD so much that I have considered picking up a new brain that has already been mapped by BFD...However, please post your results or email me directly if you are successful getting the TD-5 to map to BFD! Thanks, Ross |
well that's a little upsetting!! Hmm......have you tried contacting Fxpansion about this?
Triggers | drummer9 | The Drum Room | 1 | 09-08-2011 07:55 AM |
BFD 2 and RT-10 Triggers | arnielarsen | Pro Tools TDM Systems (Win) | 2 | 02-18-2011 06:11 PM |
Sync I/O GPI Triggers | nucelar | Post - Surround - Video | 4 | 11-30-2009 05:17 PM |
Triggers | eldusto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 02-16-2006 11:51 PM |
Triggers and module the way to go??? | bluesguy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 11-18-2005 09:03 AM |
