Old 04-18-2017, 07:08 PM
zakco zakco is offline
Default Blue D-Command not recognized by PT 12.7
Today I updated from 12.4 to 12.7 and PT no longer recognizes my Blue D-Command in the Ethernet controller dialog.
Is anyone else successfully using this combination?
To make matters murkier, I am also running on the unsupported OS 10.8.5 which had no issues running installing and running 12.7 The only problem I've seen is with the D-Command
Old 04-18-2017, 09:59 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Blue D-Command not recognized by PT 12.7
Possible?
http://lmgtfy.com/?q=ethernet+connec...running+10.8.5
Daniel
Old 04-18-2017, 10:16 PM
Thanks for the suggestion. The D-Command is working perfectly in PT10.3.8 (I run a dual install) and when I revert from PT 12.7.1 back to PT 12.4, it is once again recognized. All on OS 10.8.5, so I'm certain it's not an Ethernet issue with the OS itself.
FWIW, the D-Command is connected directly to my Mac Pro and not via a hub or router.
Oddly, I can't find any compatibility documents that mention the ICON series at all. In fact, this document lists everything under the sun as supported, not supported or incompatible, but unless I'm completely blind, the ICON controllers are not even mentioned:
http://avid.force.com/pkb/articles/e...nd-Peripherals
Your sig lists PT 12.5 - have you tried running 12.7 with your D-Command yet?
Old 04-18-2017, 11:25 PM
YYR123's Avatar
No I actually haven't made the jump myself to 12.7.
I loved 10.8.5 but I found 10.10.5 was a good place to be as well .
You might try installing a partition with 10.10.5 just for fun....
I am working on another clone of my Win10 drive and going to try installing 12.7.1 really soon.
Daniel
Old 04-19-2017, 12:24 AM
Unfortunately I need to retain my PT10HD TDM system as a dual install with PT12HD (RME hardware) and OS 10.8.5 is the last version that allows this, so no more OS updates for me I'm afraid...
I'll be interested in how your D-Command fares with PT 12.7 on Win10...if you get a chance, please report back, thanks!
Old 04-19-2017, 12:27 AM
PTPerson PTPerson is offline
You haven't changed ethernet ports on your mac? if so you need to change it when declaring the controller.
Old 04-19-2017, 03:07 AM
Will Russell's Avatar
Will Russell Will Russell is offline
PT12.7.1 and MacOS 10.12.4 and no problems with my Blue D-Command.
My guess is that running an unsupported config is the core of your problem. The last version of PT compatible with MacOS 10.8.5 was 12.4. PT12.7 required 10.9.5 and above. My advise would be to stick with a supported configuration.
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 04-19-2017, 10:16 AM
No change. In fact, when I launch PT 10.3.8 it's business as usual in port 1, so definitely not a patching issue. Good suggestion though, thanks!
Old 04-19-2017, 10:24 AM
Originally Posted by Will Russell View Post
I'm sure that you are correct and that's what i will do.
Given the last period of development from Apple and Avid, it appears that they simply don't want my money any more....so...I just stepped off the Avid Support Train at the end of March and have committed to locking down my system at that last reliable stop for a PT10/12 dual install which as it turns out is PT12.4 on OS 10.8.5
I have in fact, doubled down on this strategy and just bought a spare 6 core, 3.3 gHz Mac Pro 5.1 just in case my current rig smokes. I might also buy another pair of Accel cards as a backup! Tracking in TDM and mixing in PT12 absolutely rocks and I think I will stay here for a very, very long time!
Old 04-19-2017, 10:25 AM
Stig Eliassen's Avatar
Have you tried to reset the console? I doubt it'll help, but...
Mbox2 blue power light blinking-not recognized Verse309 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-11-2014 05:20 PM
Please help! My Command 8 is not recognized by my Mac Pro. thunderball78 ProControl, Control|24, Command|8 2 11-27-2011 10:33 PM
Help! D-Command not recognized ishur ICON & C|24 8 10-13-2008 07:49 PM
Command 8 not recognized by PT7.2 intermittent lampmusic ProControl, Control|24, Command|8 0 09-04-2006 08:45 PM
Command 8 not being recognized RobinShort ProControl, Control|24, Command|8 1 07-01-2004 12:53 PM
