Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 09-27-2013, 12:33 AM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Default Mbox/Mbox Pro & Fast Track USB/Pro Driver Updates
The following driver updates are available for download from the driver pages:
Mbox Pro (3rd gen) Drivers
  • Mac v1.2.2
  • Win v1.1.9
Mbox (3rd gen) Drivers
  • Mac v1.1.5
Fast Track Pro Drivers
  • Mac v1.9.3
Fast Track USB Drivers
  • Mac v1.9.4
Bruce Paine
System Details
Old 09-27-2013, 06:00 PM
jryser's Avatar
jryser jryser is offline
Default Re: Mbox/Mbox Pro & Fast Track USB/Pro Driver Updates
Dangit! My MBox Pro 3 tuner stopped working again. Had everything fine until now. Any way to fix this? Thanks.
Sent from my PT beating heart
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
Old 09-28-2013, 08:45 AM
serio serio is offline
It stopped working after updating to the new drivers? that sucks
For anyone interested:
This is a list of fixes included in this update:
Fixed problem where Mbox Pro Control Panel would become unresponsive if it was launched before Pro Tools
Fixed problem where Low Latency Monitoring would duplicate signal
Fixed problem where Pro Tools would not take proper control over Stereo Mix controls in Mbox Control Panel
Fixed problem where monitoring of record-enabled channels in Pro Tools with Low Latency Monitoring enabled would not function until a recording was made
I had experienced the last two problems and the bottom one seems to be addressed. But Pro Tools seems to still have a problem fully taking over the mbox control panel in LLM mode. Mono signals are fine, but if i try to monitor a stereo signal, the left channel gain is set higher than the right. This happens with any of the stereo analog inputs
Also, I didn't expect it to get fixed in a driver update, but the DSP effects are still dead.
21.5" Mid-2011 iMac i5 QUAD 2.5GHZ 4G RAM ML 10.8.5--Pro Tools 10.3.9--Avid Mbox Pro / 003R--ICY DOCK MB664UEA-1S FW400 With: 500GB Samsung HD502HJ
Old 09-28-2013, 09:00 AM
jryser's Avatar
Serio - it's you and and me again! My DSP fx work perfectly - the tuner is what's gone again! I have a comp code from my pt 11 I will use to see what's up and let u know. I can live without the tuner (have a Petersen on my phone) but I'm one of those geeks who likes things to work correctly. Undoubtedly it's an error somewhere in my gear, but I will resolve it!
Old 09-28-2013, 05:19 PM
Well the device really should work as advertised. I'm getting along ok without the broken features but it's not the point. If the box didn't sound as good as it does, I'd just stick with my trusty old 003R.
Here's some workarounds:
For anyone needing Reverb while tracking, Shan's LLM Reverb trick will work(see Pic).
As for the LLM not working properly, people can just mute the track they are recording to and then use another Stereo Mix in the Mbox Pro Control Panel to monitor with. Pro Tools only takes over Stereo Mix 1. This doesn't work for everyone's work flows though.
Old 02-22-2014, 03:47 PM
zappity zappity is offline
I'm chiming in here in the hopes of saving you some time.
I'm running PT 9.0.6, Mbox Pro 3, on OSX 10.6.8
Recently updated my Mbox driver to 1.2.2 but then kept getting "Pro Tools hardware is either not installed or used by another program" error messages. I could not get Mbox to show up as the Current Engine in the Playback Engine window (only saw Pro Tools Aggregate I/O). Upgrading directly to 1.3.0 from 1.2.2 did not work. Neither did uninstalling the driver and just installing 1.3.0
Here's what worked for me on my set up:
Download and install 1.1.5. Then, without uninstalling, upgrade to 1.3.0 directly. Restart and cross your fingers.
I hope this works for you. But wanted to let people know that I was able to get the most current Mbox driver working with Pro Tools 9.
Good luck
Old 02-24-2014, 06:21 AM
JoelG's Avatar
JoelG JoelG is offline
The 1.3 driver is for Mavericks support only, http://avid.force.com/pkb/articles/d...ox-Pro-Drivers
1.3 Nov 12, 2013
Mac OS X 10.9, 10.9.1 Mavericks support only.
Mac OS X 10.9 Requires Pro Tools 11.0.3 or higher
Mac OS X 10.9.1 Requires Pro Tools 11.1.2 or higher
Tested with Avid-qualified Apple Computers
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 04-09-2014, 12:09 AM
Delayfinder Delayfinder is offline
  • Mac v1.9.3
MacBookPro Mid 2009, MacOS 10.9.2 Mavericks, Fast Track Pro (Firmware 1.02).
The FastTrackPro Driver 1.9.3 does not work. The Interface has no audio output.
Uninstalling the driver, building an aggregate device in MacOS' Audio/MIDI setup by using the core audio drivers works.
But is there a chance to get a driver which working fine like about the last 5 years??? Please!!
Do you have an idea why the driver is not working?
Old 05-23-2014, 09:39 AM
PonchoS PonchoS is offline
[QUOTE=Delayfinder;2147475]
  • Mac v1.9.3
Yes, where are the drivers??? Will you not get us (your costumers) the drivers for OS X 10.9.x?
Old 06-05-2014, 11:07 AM
Mike J Vaughn Mike J Vaughn is offline
Wow! Huge thanks to Avid for not updating the drivers for the MBox 3 since 2013! It's not like you had any major software updates like Pro Tools 11 and it's certainly not like Mac or Windows had any software updates either.
Nope, everything is just fine. I'll continue to work in Mono since my MBox still wont output two channels. Who doesn't just love everything in MONO anyway, right?
Or, I could use the audio output of the Mac, Because I'm sure Pro Tools won't have any problems with that either.
Keep it up Avid. We'll all be Apogee, PreSonus users soon enough.
Mbox Pro Driver Updates Bruce Paine FireWire & USB Audio Interfaces (Win) 21 05-08-2023 04:55 AM
Mbox/Mbox Pro & Fast Track USB/Pro Driver Updates Bruce Paine Technical Alerts 0 09-27-2013 12:33 AM
mbox 2 factory driver updates Felix777 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-01-2012 03:09 PM
Updated Mac Drivers for Mbox, Mbox Pro and Fast Track Ultra now available Avid Technical Alerts 0 10-30-2012 04:24 PM
