Hard Drive Configuration
Need Configuration Help !!!
I have two hard drive, a WD 40G 7200RPM and a WD 6G 5400RPM. Should i put the software on a drive and record on the other ? How should i configure my system, should i put the system and protools on the same drive ? Is it better to install the system on the slowest drive and record on the fastest one or the inverse ? Is it better to plug each drive on a different connector or in slave, with the same cord ? The "scratch disk" should be set on the first or second drive ? Thank you |
Best possible hard drive configuration | Whasssaaahhh | macOS | 25 | 01-01-2011 04:11 PM |
Hard drive configuration | fat_fish | Pro Tools M-Powered (Win) | 1 | 08-10-2006 06:45 AM |
Hard drive configuration | fat_fish | Pro Tools M-Powered (Win) | 1 | 08-09-2006 05:04 PM |
? on hard drive configuration | deejfro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-07-2005 07:12 PM |
Hard Drive Configuration | Zetajazz44 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-21-2004 02:38 PM |
