Old 08-14-2006, 06:17 PM
EjA EjA is offline
Default Recording Cymbals
My synth drums are passable, but as usual the cymbals suck. My neighbor has some nice Zildgiens (?) she'll let me borrow to record. I was thinking about swapping in the resulting sound files into my recordings as needed. Has anyone done this before? I've never recorded live drums so any help would go a long way.
I have:
(1) Rode NTK
(1) Apogee Minime
ProTools 6.4
More enthusiasm than experience.
So I set them up in my living room, roll back the carpets and. . .
How far away should the mic be?
Use compression?
Where in the room is best? Corners?
EQ?
This could be a fun little project that would make my recordings a lot better, or this could be a complete waste of time.
Thoughts?
Thanks in advance,
EjA
Old 08-14-2006, 09:39 PM
Hank5 Hank5 is offline
Default Re: Recording Cymbals
I would setup in the center of the room. Avoid the corners due to reflections. Setup the mic at least 6' overhead. Experiment with mic positions to see what works and avoid compression. For eq roll off the bottom for more sizzle. Hope that helps
Warren
www.brownstonerecordingstudio.com
Old 08-15-2006, 01:12 AM
comprodman's Avatar
comprodman comprodman is offline
As it is the only thing you are recording, I would see if you can borrow another Mic as well. Have one 6 inches above at a 45 degree angle and have one 12 inches above at the other side same angle. This will give you a wider sound. Using both tracks in the mix at a 10 too and 10 past pan will give the cymbals a nice full sound.
Pro Tools Editor, Producer, Mixer and Masterer since 1998
Old 08-15-2006, 09:43 AM
rogerhavoc rogerhavoc is offline
Warren
Great tip!!!! I will save that one for my self. Great Studio BTW... You guys do awesome work there.
Peace,
Roger
www.whitenoiselab.com
MacPro 3.5 GHz 6-Core Intel Xeon E5 - Pro Tools Ultimate + HD Native + HD OMNI
MacBook Pro 2.9 GHz i7 16GB Ram (Retina, 15-inch, 2016) - Pro Tools Ultimate + Apollo Twin
iMac 27" 3.4 GHz i7 32GB Ram (Late 2012) - Pro Tools Ultimate + Mbox Pro (3rd gen)
Old 08-15-2006, 11:47 PM
cfb25 cfb25 is offline
I wouldn't put a mic within a foot of a cymbal, give it more than that in order to let the sound develop more.... if its an even decent room i might even put them two or three feet off then add that high end sizzle with eq.
Chris Beaver Music
www.myspace.com/chrisfrankmusic
The Note Music
www.myspace.com/thenotemusic
Dual 2.0Ghz PPC 3gb Ram, Digi 002R
E-drums with real cymbals - recording ideas GuitarSlinger The Drum Room 3 04-29-2010 06:36 AM
Recording drums using drum triggers & live cymbals bradweeks80 General Discussion 2 03-10-2008 03:47 PM
Hi-Hat and Cymbals torquemada Tips & Tricks 5 05-28-2006 11:58 PM
BFD cymbals cut off billya 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-06-2006 07:42 PM
Opinions on best cymbals for recording. Doug Paluch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 10-28-2002 10:00 AM
