#21
Re: HDX tracks record 21 samples late
Silly question but is
100 samples 1 second or 0.1 seconds?
#22
20 samples at 96kHz is
20samples/96000samples/second = 0.000208seconds = 0.208msec (corrected 2 posts down AVID does not publish the A/D and D/A delay times but I have measured the AVID I/Os with HD Native in Low Latency mode which is as close to the A/D + D/A time as we can know. It is 0.47ms at 96kHz and 1.9ms at 44.1kHz. I do not know what "throughput" time is. What the OP did do is what I call loopback testing. Take a signal in your DAW - send it out an output - patch that into another input and record the result. Any delay you see between the source signal and the recorded one is an error (in my book). It mimics a musician getting a headphone feed and playing exactly in time. It is the simplest of all tasks and the most basic one the DAW needs to do. So at 44.1kHz the A/D plus D/A time is ~1.9ms. Assuming A/D and D/A are equal - now we are 0.95ms of delay. So is almost a millisecond of any concern? What about 2 or 5 after a bunch of passes. Is there yet a second HDX owner that can even verify this is how it works? HDN does not work this way.
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html Last edited by propower; 01-31-2016 at 11:58 AM. |
#23
For the sake of accuracy you can't just say they "stack" on top of each other in real world recording. The musicians are "compensating" in theory. So the issue really only exists for "each pass".
#24
What the OP wrote about is that Pro Tools has the ability to compensate for the converter/transport delay *after* the record pass, since it knows what converter it's using - the OP says it is getting placed 21 samples (208 microseconds) late by this algorithm - this may or may not be the case, but is a different issue from converter throughput delay which is a known and universal issue. If Avid's "input delay compensation" is not working correctly, of course it should be fixed, but I gotta say, I'm not gonna be losing sleep over 200usec of error, unless it differs within a stereo pair or multimic'd set, and any experienced engineer knows that members of a phase-critical set should all use the same signal path/converter set (IOW, you don't split pairs/sets over multiple differing interfaces).
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 Last edited by Rich Breen; 01-31-2016 at 09:39 AM. |
#25
I've said this "a million" times but on a live gig 5ms must not be any kind of a problem. It's like having a floor monitor 1,5m away from your ears. The problem threshold is closer to 10ms
#26
I use 44.1kHz 99% of the time, BTW. So do many of us. |
#27
I'm going to post some files tomorrow to further examine this. |
#28
Good catch! I actually thought about this when I woke up knowing something was amiss !
Of course we can "get work done" with this error (should it be proven to be there). But how would this not be labeled a bug that just shouldn't be there?
2017 27" iMac 3.8GHz i5, 1TB SSD Logic ProX, Studio One V4, PT current version, Apogee Ensemble TB Musician: http://www.ivanlee.net/ Design Engineer: http://www.propowerinc.com/resume.html |
#29
It wouldn't/shouldn't be.
#30
If it is proven to be this way I can then introduce (re - acquaint) you with the DDMF MetaPlugin that is the only way I know to compensate for this in Pro Tools. I use it for every interface in Native land that has this problem.
PT9 win7x64 44 samples late recording | MikeLip | Pro Tools 9 | 0 | 11-07-2010 05:29 AM |
LE is tracking late(later than 164 samples) | macuser | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-14-2005 12:13 AM |
Recorded Audio late by 3000 samples (MBOX) | melat3mg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 12-08-2004 09:01 AM |
Recording regions a couple of samples late... | BesnikB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 19 | 05-11-2004 08:36 AM |
when i record it reaches PTF late!! Help! | matthewd | Digidesign Hardware & Software | 9 | 01-23-2004 10:00 PM |
