Old 02-27-2024, 03:24 PM
BScout BScout is offline
Default Re: is there a plugin that ...
Originally Posted by AINSLIE View Post
Maybe an answer is a multiband gate I could duplicate the track, split the eq HPF/LPF and gate each separately to kinda get there.
Any multiband compressor can be a gate if the ratio is set high enough.
And you might want to use more than 2 bands (low end you want to keep and everything else) because you might want different (knees) ratios/attack speed/release time for higher bands to make it sound more natural. And the crossfilter between bands might be tweaked. Lots to play with.
Old 02-27-2024, 08:33 PM
ReverbHead ReverbHead is offline
This could be what you are looking for, just googled multi band gate, I have never tried it.
Could probably achieve something similar with Pro MB though.
https://aixdsp.com/multi-band-gate/
Old 02-28-2024, 05:30 AM
Benny_Cha_Cha Benny_Cha_Cha is offline
Boz Digital’s Gatey Watey is a frequency-dependent gate. Might work. Still not Apple Silicon native tho.
Ben Rubin
Producer//Mixer//Bassist//Composer
benrubin.com
PT Ultimate 2024.3, Mac Studio M1 Max, 64Gb RAM, Mac OSX 13.6.4, SSD sample drive,
Neve 8816, HD Native Thunderbolt, (2) Lynx Aurora 16, Benchmark DAC-1/ADC-1
Old 02-28-2024, 06:29 AM
AINSLIE's Avatar
AINSLIE AINSLIE is offline
Works pretty well! Best solution yet. Thankyou - the evolution to search phrase 'multigate' got the bingo. At least so far ... the demo video seems to hve more parametrs available than the demo plug ...
http://www.ainsliegrosser.com/
MacBook Pro 2019 64GB OSX 10.15.7, HDX, Sonnet Chassis, PT Ultimate 2022.9, S3, Dock, MTRX Studio
Old 02-28-2024, 09:36 AM
saqibhassan saqibhassan is offline
Have you tried applying the filter via clip based fx and then using a crossfades as "attack"/"release" ?
  #16
Old 02-28-2024, 11:23 AM
AINSLIE's Avatar
This is the closest to what I was looking for although a bit too basic parameter wise. I'd have to use it in conjuction with a more traditional gate to shape the way I would want. They are working on a silicon version.
This is why i love the DUC ... thanks all for your contributions and ideas! FYI - for the tubular bells I couldnt rescue them well enough so I used a sample to replace it that sounded pretty much identical. But for toms and snares either the Boz Gatey Watey, or the aixdsp multi gate will work well. I mix tons of live records and I wish I'd asked earlier!
  #17
Old 02-28-2024, 02:52 PM
JR Fountain JR Fountain is offline
This is what you want...
https://www.blacksaltaudio.com/silencer
J.R. Fountain
credits: www.imdb.com/name/nm0288354/
system: Mac Studio Ultra, 128 GB RAM, macOS 13.6.1, MTRX Studio, S3 / Dock, PT Ultimate 2023.12
  #18
Old 02-29-2024, 08:24 AM
AINSLIE's Avatar
Originally Posted by JR Fountain View Post
Thankyou - this is the winner - works great on drums. Kinda like ClarityVX from waves, but for drums. Really good. Thankyou JR!
  #19
Old 03-04-2024, 03:36 AM
My pleasure Ainslie! Glad it worked for you.
J.R. Fountain
  #20
Old 03-05-2024, 01:51 AM
simon.a.billington simon.a.billington is offline
Synthesisers have this as a pretty much standard feature. A filter, set to Low Pass, and an "envelope" set to modulate the fall of rate of the filter.
This doesn't help you, though if you can find what you're looking for if you look at audio filters based on this synthesizer process. Waves Metafilter for example or the filters from Artuiria.
Metafilter doesn't have an envelope as such, but it can be set to Follow the input, and set it up the sequencer or a saw LFO to automate the fall of the filter.
HTML code is On
Plugin Window is too small cutting off access to most of the plugin GOOOTOOO Pro Tools 2020 7 09-21-2020 07:38 PM
Schoeps DOUBLE MS PLUGIN (2018) SURROUND PLUGIN FOR AAX finally available! bartosz idzi AAX Plug-ins 1 12-16-2018 03:49 AM
Bug: When selecting a favorite plugin insert, the plugin above the one selected opens DJ Hellfire Pro Tools 12 35 08-22-2017 08:05 PM
v control (v2) plugin encoder cannot instantiate plugin screen in PT10.0.1 klyg Artist Series 2 02-29-2012 10:50 PM
Vocal plugin needed to change voice, what is the best plugin Logicdance Digidesign Hardware & Software 0 03-13-2007 04:26 AM
