Old 12-04-2023, 03:05 AM
irrklang irrklang is offline
Default Fader issue in touch mode
Hello,
I switched from a hui controller to the avid artist control and got the following issue:
For example the first path of a track has 0dB volume automation.
I´m in touch mode, no preview, and I reduce, while playing, the volume to -10dB by fader. This works fine for about 20 seconds. Then the fader forces to go back to 0dB while I try holding it at -10dB. I stop and my automation looks like a mountain scenery.
Same procedure in latch mode, everything is fine and the volume stays at -10.
Anybody an idea?
Cheers Harald
Old 12-04-2023, 07:16 AM
EddieJones's Avatar
Default Re: Fader issue in touch mode
Sound like a dirty fader. Move the track to another one and see if that works. Then search for cleaning faders on here.
Sent from my SM-S918U using Tapatalk
Old 12-04-2023, 08:00 AM
Nope, on all faders…
Touch Mode in Latch Mode antony papa Pro Tools 6 09-01-2023 06:48 AM
Shift Touch Fader in Flip mode problem. mattrixx Avid S1, S3, Dock and Control App 2 06-30-2017 05:36 PM
MIDI Fader Touch Mode Jon E. Pro Tools 12 1 10-13-2015 06:16 AM
Control 24 self test, no fader values touch mode Analogue_Rocks ProControl, Control|24, Command|8 0 06-13-2015 01:47 AM
Digi 002 - flying fader issue in flip mode bluemanna 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 11-14-2003 01:54 AM
