Old 08-16-2017, 11:37 AM
Kristo Kotkas Kristo Kotkas is offline
Default Ilok drama! "Authorization exception" error
It looks like there is something wrong with ilok software on S3L & S6L resulting McDSP, Sonnox & Crane Song plugins stopping working. I'll re-post Ryan's fix from Facebook S6L community here too:
Ryan O John
16 hrs
If you're using McDSP, Sonnox or CraneSong plugins, do not sync your ilok with license manager. The certificate for license manager has expired, and syncing your ilok may stop plugins from working. Dealing with PACE right now to get this fixed ASAP.
Run this installer, it fixes the PACE timeout FOR S6L and S3L ONLY: http://avid.force.com/pkb/articles/f...-VENUE-systems
For S6L and S3L ONLY:
Exit to desktop by holding control and hit shut down, run this installer,
Double click "return to venue,"
and then restart the system.
Good to go
Old 08-16-2017, 01:23 PM
kaiyajoy kaiyajoy is offline
Default Re: Ilok drama!
Had this issue on S6L, followed this Avid link courtesy of the wonderful folks at McDSP and it fixed the issue.
Old 10-09-2017, 10:11 AM
brinnbacka brinnbacka is offline
Default Re: Ilok drama! "Authorization exception" error
I have the same issue on S6L / 5.3.3.30, even after installing the new PACE -software and failing it with error "-3", which apparently should tell it's already installed. Anyone else with similar issues?
Old 10-11-2017, 12:33 PM
RyanJ's Avatar
RyanJ RyanJ is offline
which plugins were you seeing that error with?
Ryan John
Principal Product Manager | Avid Live Sound
[email protected]
Old 10-11-2017, 09:54 PM
McDSP and Sonnox, but turns out I just needed to show some internet to the iLok Manager and everything was fine.
Old 10-16-2017, 03:41 PM
RyanJ's Avatar
glad it worked out!
Ryan John
[email protected]
Old 12-20-2017, 03:56 PM
channelaudio channelaudio is offline
I was having the exact same issue. Thanks!
___________________
Channel Audio - AV Equipment Rental & Event Production
https://www.channelaudiogroup.com/
iLok freaking out today: Authorization Exception [email protected] Licensing & Accounts 56 08-26-2017 02:59 PM
Authorization Wire Exception error in Pro Tools 12 TVPostSound Pro Tools 12 20 01-15-2017 11:59 PM
Ayuda con este error : Authorization Wire Exception AnderTools Foro en Español 18 11-27-2016 06:52 PM
error: missing ilok authorization for pro tools... please insert the necessary ilok. Witold.B Pro Tools Express on Mac OS X 1 04-21-2014 03:59 AM
Floppy Authorization Drama venusmuzik Tips & Tricks 0 10-16-2002 04:00 AM
