Old 04-14-2016, 02:48 PM
EddieJones's Avatar
Default Pro Tools 12.5.0 Can Cause Loss of Backwards-Compatibility of Layouts
Due to an unintended change made to Pro Tools 12.5.0, Layouts created for Artist Series media controllers, System 5 Hybrid and, to a lesser extent, S6 can lose track assignments when a Pro Tools 12.5.0 session is opened in an earlier version of Pro Tools. This problem is related to Track IDs.
In most (but not all) cases, simply opening and saving the session in Pro Tools 12.5.1 or later restores backwards compatibility.
Specifically:
· With any session opened and saved in 12.5.0 and then opened in 12.4 or earlier, all Layouts will be broken for S3, Artist Control and Artist Mix (see note about S6, below). However, if the same session is opened and saved in Pro Tools 12.5.1 or later, all Track IDs will be fixed such that Layouts will work if the session is opened in Pro Tools 12.4.x and earlier.
· New tracks created in Pro Tools 12.5.0 and saved in a Layout will be lost from the Layout if the session is opened in Pro Tools 12.4.x or earlier, but will be present when opened in Pro Tools 12.5.1 or later.
o S6 Note: Tracks created in Pro Tools 12.5.0 and saved to an S6 Layout will remain as long as the new tracks have not been renamed or moved in Pro Tools 12.5.0.
Old 04-14-2016, 07:44 PM
jjnssn jjnssn is offline
Default Re: Pro Tools 12.5.0 Can Cause Loss of Backwards-Compatibility of Layouts
So when will 12.5.1 drop?
Old 04-14-2016, 07:45 PM
EddieJones's Avatar
I can't give an exact date but its in beta testing now.....soon
Old 05-13-2016, 05:22 AM
Becharax's Avatar
Becharax Becharax is offline
Still Waiting !
System Details:
iMac Pro 2017 8 Core Intel Xeon 3.2 Ghz
Macbook M2 Pro
macOS 14.4.1
Pro Tools 2024.3.1
Logic Pro X
Reason 12
UA Apollo 8p
Apogee Thunderbridge/Apogee Symphony I/O 2x6
Eleven Rack/Focusrite ISA Two/Onyx 1640i
UAD Satellite Quad
MOOG Mother 32
Nektar Panorama P1
Axiom AIR 49/Axiom 49/Yamaha P35
Fender Mustang/Marshall Amp/Ibanez Pedals/Fender Strat/Yamaha FG820L/Martin DJr10e
Genelec 8040b/Yamaha HS80s/M-Audio BX5a
Beats Solo/Shure SRH1840/Slate VMS
https://open.spotify.com/artist/7KfV..._branch=1&nd=1
Old 05-13-2016, 05:29 PM
EddieJones's Avatar
Sorry...still testing.
Old 05-14-2016, 06:58 AM
tamasdragon tamasdragon is offline
Don't rush it, release it when it's really ready. So far all the S6 updates has been flawless and I really appreciate that! And thanks for being so supportive here also.
my blog:Tamas Dragon
Old 05-22-2016, 03:47 PM
Has this been fixed in 12.5.1?
Old 05-22-2016, 04:10 PM
EddieJones's Avatar
Yes fixed in 12.5.1 but layouts built in 12.5.0 may not load correctly. Resave them in 12.5.1.
Old 05-22-2016, 05:22 PM
Thank you.
backwards compatibility with pro tools 8? klownstyle Pro Tools 9 2 11-05-2010 08:00 AM
Backwards Compatibility kloqwyse 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 01-28-2010 05:11 PM
Backwards Compatibility cooldude76230 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 11-18-2006 03:51 PM
001 Backwards Compatibility$ mutation generation 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-09-2000 11:35 PM
Backwards Compatibility noizboyz Storage Subsystems 1 07-07-1999 05:37 PM
