Old 03-19-2015, 08:30 PM
JCK43232 JCK43232 is offline
Default Move AIR Music Technology folder in Applications folder???
Hello,
Just installed a fresh copy of Pro Tools 11.3.1 on a Retina MaBook Pro running 10.9.5.
I also installed the AIR Creative Collection and allowed it to use the default install location (without investigating to see where the default install location pointed)
I know have an "AIR Music Technology" folder in my Applications folder that contains five folders, (one for each of the VI's ???). Is it possible/advisable to change the location of the AIR Music Technology folder???
I was considering moving it to the same folder to which I installed Pro Tools?????
I am guessing it defaulted to installing in the root of the Applications folder so other apps could also make use of the plug-ins????
Thanks
John
Old 03-20-2015, 04:51 PM
junkgear's Avatar
junkgear junkgear is online now
Default Re: Move AIR Music Technology folder in Applications folder???
The plug-ins themselves are copied to specify folders, where the DAW expects to see them. Therefore, you probably could move the folder, although I would still advise against it. Moving the folder could cause other issues, uninstall would be one that comes to mind.
Will
System Details
Old 03-20-2015, 08:17 PM
Thanks for the info . . .
I went back and ran the installer again and realized that it does not give any options (other than drive/partition) when installing.
I am also not seeing any "un-installer" anywhere. Just seems odd that this plug-in places items in my Applications folder. I don't use a lot of plug-ins but so far this is the only one one that does so . . .
John
Old 03-21-2015, 05:44 AM
junkgear's Avatar
I have others that create folders in Applications as well, so it's not just limited to AIR.
I don't really know the reason, but maybe someone else will chime in that does know.
Will
System Details
Old 03-21-2015, 06:24 AM
It's always best to let an application installer install wherever it wants to. Mess around with that and you can open up issues particularly when it comes to updating things. A lot of updaters will look in the default location and barf if the program is not there. Which means on a Mac PT11 installs in the Applications folder which is different than the install for PT10 which goes in a folder named Avid in the Applications folder.
Besides - why would you want to move the install?
Jack
QAPLA!
Old 03-22-2015, 11:38 PM
clausiii's Avatar
clausiii clausiii is offline
I think he talks about the samples/content folder, not the plugin itself! And yes, you can move it and the plugin asks where the content is after inserting it.
My ears! My ears!
clausiii
MacBook Pro i7 Quad 2.6GHz 16GB RAM
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
Digidesign Command|8
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Old 03-23-2015, 05:33 AM
Could be but we're not sure. I seem to get the feeling he's talking about the actual plugins themselves.
Jack
QAPLA!
Old 03-23-2015, 05:36 AM
clausiii's Avatar
Normaly there is no AiR folder in the plugin folder. But there is a content folder in the application folder.
My ears! My ears!
clausiii
ProTools 2020.11
Avid S1
Avid Dock
Avid Control
macOS Catalina
MOTU 4pre
MOTU Track16
Axiom Pro 25
LinnStrument 128
Roli Seaboard Block
tons of stomp boxes
tube amps
guitars
noise
Plug In folder/support folder corrupted?? jeffpardo Pro Tools 11 0 05-30-2014 07:46 AM
air music technology folder Fabulous AAX Plug-ins 1 04-17-2014 08:25 AM
Why can't I set my plugins root settings folder outside PT's default folder? RiF Pro Tools 9 4 09-26-2011 12:11 PM
Plug-Ins Alias folder points to wrong folder??? nod25 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-26-2009 03:43 PM
Please HELP!!! need to move my PT plug ins folder! scidef 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-11-2007 09:07 AM
