Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 01-29-2016, 12:47 PM
simon lefisch's Avatar
simon lefisch simon lefisch is offline
Default Digi 002 Kernel Task Issue
For those who still wish to use the 002/r on El Capitan, I was able to get my 002r working using the 10.3.3 drivers. Initial testing looks good. Haven't put it they a hard test yet (20+ tracks). So far it runs great on Ableton and Logic (can't say anything for Pro Tools since I don't use it anymore). Just make sure to remove DigiDioMidiDriver.plugin file from the Midi Drivers folder (located in HD>Library>Audio>Midi Drivers) as that has caused problems in the past.
Note: DO NOT USE THE 11.x DRIVERS!! These drivers still have the kernel_task error when running your 002/r.
Macbook Pro 2.2GHz (late 2011 model), 16GB RAM, OSX 10.7.5
Old 06-11-2016, 04:52 AM
darkbridge darkbridge is offline
Default Re: Digi 002 Kernel Task Issue
Hello. I tried you solution, but in this case avid 002r doesn't work as output in system pref for itunes or for any player or online music or youtube, it works only with Logic, Protools etc.
And actually i didn't delete DigiDioMidiDriver.plugin.
What i did, i just used soundflowerbed. Old version with app, not only with drivers.
So i am using OSX 10.8.5, soundflowerbed and 10.3.3 drivers.
I tried el capitan, but in el capitan soundflower crashes very often and it has sound cracking everytime.
If someone need old soundflowerbed, just write me on email [email protected]
Old 06-18-2016, 10:17 AM
For those who are having problems with freezing system with latest drivers and kernel_task, there is a solution. It really works.
1) Open System Information (under Apple icon in upper-left, click About This Mac, click More Info)
2) Click System Report button, under Hardware, find your "Model Identifier" -remember this for later use
3) Navigate to /System/Library/Extensions an right-click, Show Package Contents of IOPlatformPluginFamily.kext
4) Open Contents/PlugIns and Show Package Contents of ACPI_SMC_PlatformPlugin.kext
5) Open Contents/Resources
6) Find your MacBookAir?_?.plist (? = your model identifier from step 2) and delete the file
7) Reboot! Remember, anytime you do a System Update, you may need to repeat this process
So now i am using MacBook 5.2, with driver 11.1.3, osx mountain lion 10.8.5 and i don't use soundflowerbed for system soundoutput. Working like a charm.
Old 06-27-2016, 02:10 AM
lowpass lowpass is offline
Darkbridge: many thanks for this workaround, it really cured a plague that affected my system for the last 2 years!
Old 06-27-2016, 07:59 AM
Well, actually i forget to tell, that if you won't to use digi 002r with any DAW, you need to go to HD/Library/Audio/Midi drivers and delete or remove somewhere all files from this folder except Avid 003 Family.plugin.
After that restart and it will work, but midi in/out MAYBE will not work.
  #16
Old 06-27-2016, 08:12 AM
As I had stated in my previous post, it only worked for Logic/Ableton. I never said anything about using it for iTunes/etc.
  #17
Old 06-27-2016, 09:43 AM
That's ok, now all is working:)
  #18
Old 12-21-2016, 04:59 PM
ibanezjp ibanezjp is offline
I have tried this but it won't let me delete my iMac12_2.plist file. It says it is required by OS X and can't be modified or deleted. How did you delete it? I am on 10.11.3 El Capitan
  #19
Old 12-22-2016, 09:30 PM
So I found a way to delete the file by starting up in recovery mode then using terminal to disable the security. It still didn't help the issue but I also installed the newest 003 drivers from October and they really helped. It took the kernel task usage from 105% down to around 40-45%. Still not as low as it should be but much more accepatable and I don't get playback errors anymore. So seems like this will work for now.
Wierd sync/task manager issue orage 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-20-2007 01:40 PM
TASK MANAGER ISSUE - Can U Help ?? danocaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-06-2006 06:55 PM
kernel panic caused by Digi 002 rack oreo1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-18-2006 12:22 PM
Idle Digi 001 running at 100% CPU usage in XP Task Manager Help Ajay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 18 04-21-2003 11:44 PM
Digi Tech re: PTLE 6 crash & kernel panic logs. dkrz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-03-2003 07:30 AM
