Old 04-08-2014, 12:57 PM
11w 11w is offline
Default VI presets
Hi everyone,
Since I switched into OS X 10.9.2, all the Virtual instruments presets are missing and same thing for the FX sections, if I click on xpand2 I can't go through the preset list, same for the build in EQ, can't go into the presets, any help?
Old 04-08-2014, 02:09 PM
Default Re: VI presets
Originally Posted by 11w View Post
Hi everyone,
PT10 any version has not been okayed by Avid for use on Mavericks and probably won't be. You may want to download again the instruments and re-install them.
Jack
QAPLA!
Old 04-08-2014, 02:16 PM
11w 11w is offline
That's the very 1st thing I did and it didn't fix the problem
Old 04-08-2014, 03:23 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Not sure why I have duplicates of these, but for the RTAS version of Expand, the presets are located here:
Macintosh HD/Library/Application Support/Digidesign/Plug-In Settings
In these 2 folders:
Xpand!2
XPand2
For the AAX version, the presets are located here:
Macintosh HD/Users/username/Documents/Pro Tools/Plug-In Settings
In these 2 folders:
Xpand!2
XPand2
If you have those 2 folders in one location, but not the other, I would try copying those 2 folders to the other location.
I'm running Pro Tools 11.1.2 on Mac OS X 10.9.2, and removed the Pro Tools 10 application when I went to Mavericks. I left some of the old folders from PT 10 on my system for future reference (posts like this one )
I'm not sure whether you are using the RTAS or the AAX version of Xpand2 if you are on the latest version of Pro Tools 10.
Bruce Paine
System Details
Old 04-09-2014, 09:12 AM
11w 11w is offline
Tried that and worked, everything back to normal. Thank you very much
Hypercontrol: Convert plugin build-in presets to pro tools plugin presets headsup macOS 4 12-17-2011 01:28 PM
EQ III Presets tucum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-05-2005 07:53 AM
Where can I get presets for EQ III? mdotbeatz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-22-2005 09:36 PM
Presets Jim Wicks Pro Tools TDM Systems (Mac) 1 09-10-2003 09:11 AM
D-fx Presets Rferguson Pro Tools TDM Systems (Mac) 1 04-05-2000 10:09 AM
