  #71
Old 02-22-2017, 02:44 PM
Barry Johns Barry Johns is offline
Default Re: ProControl with Pro Tools HD 8
Originally Posted by lltj56ace View Post
Hello everyone
Been a while sense I been here. I have a problem and I know this is the place that can help me with my problem. I have The Pro Tools HD system. It consist of The digidesign Pro Control Midi Sync i/o The Digidesign Pre and 6 192 interfaces. I know it has all the plug-ins, But i would like to incorporate outboard gear like a compressor, an EQ and also reverb like the alesis midi verb4. So in lay mens terms could someone please help me add this to my rig it would be highly appreciated.
For you to incorporate outboard, you have to use the same channel for the send and return. Example, route out of Digi 192 Channel 3 Out - to Input of first Outboard, lets say a compressor, then out of the compressor, back to the same Digi 192 Channel 3 Input.
You can't go out of channel 3, and then return back into channel 4 as example. Has to be the same. Out Channel 3, back in Channel 3. Out Channel 8, back in Channel 8.
The above are for physical connections. You also have to setup the routing within hour I/O inside protools.
HD Native Pcie, PTHD 11, PT12 Vanilla, Omni, Lynx Aurora 16, 192 I/O (16 in/8 out), 24 Fader D-Command, lots of preamps and compressors.
MacPro 5.1 (12) Core (2009 MacPro 8 Core Upgraded to a 12 Core MacPro), 56 Gig Ram, SSD System & 3 - 2TB Drives, OSX 10.9.5, Windows 10 Via Bootcamp
Control|24 and ProControl with Pro Tools 11? xStix99x ProControl, Control|24, Command|8 2211 04-29-2019 01:23 PM
ProControl in Pro Tools 9 BejankaMop ProControl, Control|24, Command|8 5 11-12-2012 01:31 PM
pro tools hd 9 and procontrol djgusmusic macOS 0 07-10-2012 09:11 AM
Pro Tools HD2 8.1-9.0 using ProControl jpd52 Pro Tools TDM Systems (Mac) 0 01-22-2011 06:37 PM
ProControl working with Pro Tools 9 brdst Post - Surround - Video 1 11-08-2010 02:49 PM
