Go Back   Avid Pro Audio Community > Pro Tools Hardware > FireWire & USB Audio Interfaces (Mac)
Old 07-01-2013, 10:04 PM
drumzalicious drumzalicious is offline
Default Help with MBOX 3 Pro
Has anyone successfully used the MBOX 3 Pro and all of its ouputs with Logic/Pro Tools simultaneously? In a situation where I'm running live tracks and the tracks are usually run through Logic to prevent having to carry an iLok around however I have been unable to get Logic to play through all 6 of the outputs. For example we are trying to split the tracks into stereo guitars, stereo keys, mono drum loop and a mono click. Currently when trying to run it though EVERYTHING comes down outputs 1-2. In Logic we have tried to have individual channels going to individual outputs and also tried setting up busses for those outputs and routing them that way however everything STILL comes through 1-2.
EDIT:
Tried Pro Tools with the MBOX 3 Pro and still couldn't get sound to come independently down all 6 outputs. Everything would come out of 1 and 2 and I spent about 30 min or so trying to get it all working to eventually make an aggregate I/O with an MBOX 3 to get 4 splits working. Any Help would be appreciated.
Old 07-09-2013, 10:07 AM
Default Re: Help with MBOX 3 Pro
bumpity.
Old 07-09-2013, 11:00 AM
nst7 nst7 is offline
Default Re: MBOX 3 Pro with Logic
I think you need to first configure this in the Mbox Pro Control Panel software. Depending on what you want to do, you either need to set all 6 outputs to just line outs (no monitor control), or set it up for 5.1 surround monitoring (all 6 outputs are affected by volume knob/mute button, etc. the manual tells how to do either setup. But it must be set up that way first in the control software, before the options will show up in your DAW (Protools or otherwise).
Old 07-09-2013, 11:34 AM
You might find quicker help better posting on a Logic forum.
Old 07-09-2013, 12:33 PM
Hmm. I will try the 5.1 thing and see if it works. Any other suggestions?
Old 01-22-2017, 06:09 PM
mike081377 mike081377 is offline
How can I get my mbox 3 to work with Logic Pro x please someone help meeeee lol . Don't know how to go about it
Does anyone here use an Mbox with Logic? ikon1234 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-21-2004 05:20 PM
Logic and MBox dclark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-28-2004 12:26 AM
anyone using Logic w/ Mbox? OSX? kalil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-14-2003 02:32 PM
Logic & MBox on Mac Bambison 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-29-2003 02:09 PM
logic 5 and Mbox ariel keshet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-14-2002 03:10 PM
